Question about Nintendo Wii U
Error code 105-4207,103-1002,108-0144
Will not download updates
How do I Fix Windows Update Error 0x800F081F?
.NET Framework 3.5 installation error: 0x800F0906, 0x800F081F, 0x800F0907 Error code 0x800F0906
Error code 0x800F081F
Error code 0x800F0907 Resolution for Windows 10 0" style="box-sizing: border-box; outline: none;"> Error code 0x800F0906, 0x800F081F, or 0x800F0907
Error code 0x800F0922 More Information 0" style="box-sizing: border-box; outline: none;"> These errors may occur when you use an installation wizard, the Deployment Image Servicing and Management (DISM) tool, or Windows PowerShell commands to enable the .NET Framework 3.5.
In Windows 10, Windows 8.1, Windows 8, Windows Server 2012 R2, and Windows Server 2012, the .Net Framework 3.5 is a Feature on Demand. The metadata for Features on Demand is included. However, the binaries and other files associated with the feature are not included. When you enable a feature, Windows tries to contact Windows Update to download the missing information to install the feature. The network configuration and how computers are configured to install updates in the environment can affect this process. Therefore, you may encounter errors when you first install these features.
Error messages that are associated with these error codes
Error code Error messages 0x800F0906 The source files could not be downloaded.
Use the "source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
Windows couldn't complete the requested changes.
Windows couldn't connect to the Internet to download necessary files. Make sure that you're connected to the Internet, and click "Retry" to try again.
Installation of one or more roles, role services, or features failed.
The source files could not be found. Try installing the roles, role services, or features again in a new Add Roles and Features Wizard session, and on the Confirmation page of the wizard, click "Specify an alternate source path" to specify a valid location of the source files that are required for the installation. The location must be accessible by the computer account of the destination server.
0x800F0906 - CBS_E_DOWNLOAD_FAILURE
Error code: 0x800F0906
Error: 0x800f0906 0x800F081F The source files could not be found.
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
0x800F081F - CBS_E_SOURCE_MISSING
Error code: 0x800F081F
Error: 0x800F081F 0x800F0907 DISM failed. No operation was performed.
For more information, review the log file.
Because of network policy settings, Windows couldn't connect to the Internet to download files that are required to complete the requested changes. Contact your network administrator for more information.
0x800F0907 - CBS_E_GROUPPOLICY_DISALLOWED
Error code: 0x800F0907
Error: 0x800F0907
How to download the .NET Framework 3.5 outside of the Windows Update requirement
The .NET Framework 3.5 is available for customers with Volume Licensing or MSDN Subscription, as Feature on Demand Media is available.
Error codes are not listed when you install .NET Framework 3.5
When you install .NET Framework 3.5, you may encounter other error codes that are not listed in this KB, for more information, go to the following articles:
Dec 27, 2017 | Computers & Internet
STATUS CODE 4099-4174-1600-0700-C000-000E
Xbox.com has a handy search page to lookup error codes:
http://support.xbox.com/en-US/error-code-lookup
From that page, those is the answer and resolution they give, good luck:
" Error C000-000E occurs when you try to download an update to your Xbox 360 console
Problem
You see the following error when you try to download an update to your Xbox 360 console:
error code xxxx-xxxx-xxxx-xxxx-C000-000E
Update failed.
Note In this error code, the "x" digits vary.
This error message means your console could not download a software update from Xbox Live.
Solutions
To resolve this problem, try the following solutions:
Solution 1: Try installing the update again.
Solution 2: If you're having problems connecting or staying connected to Xbox Live, see Troubleshoot your Xbox Live connection.
Note You can also update your console software by copying the update to a USB flash drive or a disc and then applying it to the console. "
Jun 13, 2014 | Microsoft Xbox 360 Console
How do fix error code 8002 f14e
that is a update error. try going to the official ps3 site and download the latest update onto the stick then update the ps3 via storage media. it may take a few attempts but it should eventually work
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Need to fix a ps3 with 8002f1f9 error code. where
PS3 has a **** poor wireless card i would run a cable for your internet connection.You can DOWNLOAD the update and get instructions here
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
How to fix this problem
http://www.vistaheads.com/forums/microsoft-public-windowsupdate/322548-error-646-a.html read that page, has all the info you need on how to get info and the official MS page to fix it.
Should be able to help you properly
Jan 03, 2010 | Microsoft Windows Vista Home Premium with...
I try to update and get error code 8002f9546 or close to that
The error code 8002f994 means that there are to many people downloading the update. Im not sure if that is the code u got but try waiting until the early morning hours to download
Aug 08, 2009 | Sony Playstation 3 (PS3) Console
360 dashboard update error problem
Look on the Microsoft website and download the lastest update to a Storage Media device. It maybe that the data you downloaded from your Xbox360 is corrupt.
Jul 28, 2009 | Microsoft Video Game Consoles & Games
PS3 update problems
Hello!!
Ok, no matter how you try to install the firmware it will always write it to the hard drive first before install. Now if it gives you the 800 error while downloading it's your hard drive and it may need to be re-formatted or replaced. If you get an error during installation, then therewas a misplaced piece of code during the download and it needs to be downloaded again.
BTW, the power button default reset is ONLY for the Video output settings.
Hope this helps. Good luck and happy gaming!!
Oct 22, 2008 | Sony Playstation 3 (PS3) Console
Nintendo Wii U Logo
363 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
