Question about Onkyo TX-SV535 Receiver
Onkyo tx-sv535 goes into protection mode after blowing the fuse (i have since replaced it)
I accidentally touched 2 of the speaker wires together while it was turned on and the reciever sparked and shut off. I checked and the fuse inside was blown but i couldn't see any other noticable damage. I replaced the fuse and now when i turn on the reciever it goes into protect mode. I've tried reseting it but got the same results.
SOURCE: Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
Posted on Sep 05, 2007
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
SOURCE: stuck in protect mode
i believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
Posted on Dec 11, 2008
barbu51
  • 566 Answers
SOURCE: my onkyo receiver (tx8511) keeps going to protect
Hi there
To answer your question;
Your amplifier goes into protect mode when it detects a fault or condition that could damage the speakers and/or the output stage.
Often caused by shorted outputs.
Although this does`nt tell you much on how to fix this problem, the best help i can give you at this point is to tell you to have it looked at by a repair shop.
Hope this help good luck
Posted on Apr 18, 2010
SOURCE: How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
Posted on Jan 29, 2011
My Onkyo tx-ds595 reciever turns on but after 5 seconds it goes into protect mode. I really would like to fix this porblem myself. Please help.
This can be caused by shorted speakers or speaker wiring, disconnect all the speakers and see if the problem goes away.
Mar 04, 2011 | Onkyo Audio Players & Recorders
Hi, after i turn the power on and then press the stand-by button, it clicks off to stand-by mode instantly. This is an Onkyo TX-SR500
This indicates that the system is going into protect mode. First disconnect all speaker wires (with the power cable disconnected). Then turn the unit on and see if it sill shuts aff ofter a few seconds. If it does not, then you have a problem with the speakers or speaker wires. inspect the wires at both ends for frayed strands that may touch. If that all lookd good, plu the speakers in, one at a time, until the problem reappears. Be sure to turn the sytem off before plugging in any speaker just to prevent any accidental short which could be catastrophic. If the system goes into protect mode with all speakers disconnected, you probably have a shorted output transistor.
Apr 05, 2010 | Onkyo TX-SR500 Receiver
Turn on power and the amp goes to protect mode
disconnect the speakers and see if it does the same thing.
if it does not shut down,check that the speaker wires are not touching on the back of the speakers.
many times,people run over the wires with a vacuum or similar and a short results,or bump the speaker.most people have the leads way too long,and even if one strand touches,it will shut down the amp.
if it still shutting off,there is an internal problem.
the best place to go with an onkyo is an authorized depot.
they are tricky to work on.
i did onkyo warranty for 7 years.
Sep 06, 2009 | Onkyo TX-DS939 Receiver
The HT-R510 unit's overheat protection kicked in
Hey there..Sorry.When the amps are over powered they blow the main circuit and short causing the amp to turn on the right back off to protect mode.That you will have to send in to get fix..Look behind the amp and see if theres any wires touching or grounding out.My favorite amps are from onkyo and believe me i've done this a few times to 5 aps I've had.So I up graded to the tx sr 906 It rocks and will blow every speaker I have before the amp will go..Hope this helps you and good luck..Have a great day...
Apr 02, 2009 | Audio Players & Recorders
Every time I turn on my Onkyo receiver it goes in to protect mode.
Please check your speaker cables. Make sure that all of them are seated properly, none is touching each other or to the body of receiver.
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny frayed speaker cable touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough to activate and it could blow a few trasistors in the power output circuit.
Please take out all the speaker cables, unplug your receiver from the mains and try to restart without any cables plugged. If it powers on then you are lucky.
If not and the receiver still goes into protect mode or wont turn on then it possible that there are bad connections on the main board or have some blown transistors. How old is your system? if its still under warranty then you should contact Onkyo immidiately.
Let me know if I can be of any further help. Please do rate this solution and thanks for using FixYa!
Mar 08, 2009 | Onkyo TX-SV727 Receiver
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Mar 08, 2009 | Onkyo TX-8511 Receiver
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
Onkyo ts595 goes into protect mode with volume increase
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
Aug 03, 2008 | Onkyo TX-DS575 Receiver
Onkyo tx-sv535
when the apm in protect mode means it is problem in inside.don't trow it please repair it n use
Jan 02, 2008 | Onkyo TX-SV535 Receiver
51 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
