Question about Locks & Locksmithing
Here's my serial number to Pentagon safe AP 090605003 and since returning back overseas forgot digital code and can't find over ride code the company doesn't return my calls how can I ope
SOURCE: I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Posted on Apr 27, 2009
  • 124 Answers
SOURCE: i forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Posted on Sep 14, 2009
  • 3 Answers
SOURCE: electronic secuity pin ( 4 digits ) no longer
it sounds like it has reverted to it's factory setting if you can find the hand book it should be in there
Posted on Nov 17, 2009
  • 3 Answers
SOURCE: I forgot my code and misplaced the overidde key
Most of the time if you contact the manufacture on these types of safes they can help you through a reset or they can send out a key in the mail to you. I had a problem like this with another brand and they were able to send out a replacement. Good luck.
Posted on May 26, 2010
SOURCE: Where do i get instructions for changing the code
I had this exact same problem. Then I realized the red reset button was actually INSIDE the safe itself. So you need to enter the factory default code "159" to open the safe, then on the inside of the safe next to where the batteries are is a red button. If you press that, the yellow light will flash and you'll get two beeps. That means you can now enter your own combination. I hope this helps.
-Mike
Posted on Jul 18, 2010
Forgot code for my sentry safe no serial number
Without the code or a serial number you might just as well take out the plastic explosives!
Mar 28, 2016 | Home Security
Tip
How To Open Your Kingavon Electronic Safe 28
<ol> <li>The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.</li> <li> Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.</li> <li> Test your new code several times before locking.</li> <li> If you don't have an over ride key, the first three digits of the serial number should be the key code.</li></ol>
on Feb 21, 2011 | Kitchen Appliances - Others
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
How to open or override my 1960's sentry Combination safe
Your only solution if you can not find your owners manual it is posted in is to order keys and combination from the serial number on the safe or drill out the locks
Jan 06, 2013 | Sentry FIRE-SAFE Combination Safe DS3431,...
I forgot my nokia 2700 c2 security code my phone IMEI no 354350/04/597801/3 pls help me i have my very useful contact on it and i m facing problem pls.
The master code is a 10 digit number that will always be accepted as if it were your actual security code. You can use the master code to change your security code back to what ever you like. When your Nokia handset asks you for the security code simply enter the master code.
The master code is specific to your handset and is generated using the handset 15 digit IMEI number (serial number). The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Find Nokia Master Security Code. Simply enter your 15 digit serial / IMEI number. Your master code will then be calculated instantly. Cick here to find your master security code.
Jul 19, 2011 | Nokia Classic 2700 Cell Phone
Kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
Feb 24, 2010 | Safe International Digital Electronic Safe...
We forgot the combination to our Sentry Fire Safe Model 1610 HELP
Contact SENTRY
Sentry Group
Attn: Dept. 200 882 Linden Avenue
Rochester, NY 14625-2784
Please allow 7-10 business days, upon receipt of your request, to receive your combination.
This request may be faxed to us at : 585-381-2940.
The combination will be faxed or e-mailed back to you only if requested to do so on your correspondence and you have included a copy of a $15* money order on your fax (please allow 24 hours for processing your faxed request).
To pay by MasterCard or Visa please contact our Customer Service Department at 1-800-828-1438 (please do not fax your credit card number).
Jul 31, 2009 | Sentry Fire-Safe Media File - SEN6720
Safe mode
Radio needs to be removed from dashboard. get the serial number from the ride side of the radio and call dealer with the vin# and the radio serial number and you can get the unlock code
Jul 12, 2008 | 1996 Volkswagen Cabrio
Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
Jan 23, 2008 | Sentry Fireproof Safe
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
