Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Cleaning my bissell 1699 and diverter came off when lifting the cover off. How do I re-install it? Thank you!
  • Official Brand Answer
  • 315 Answers
You may want to contact a BISSELL Authorized Service Center to have a qualified technician inspect your machine.
Here's a quick link to locating one. http://www.bissell.com/service-centers/?cid=ccsocial
Posted on Jan 07, 2013
SOURCE: Smart Mix selector
I figured it out,since you nor Bissell was of no help. It turns out to be quite easy.
Posted on Jul 22, 2008
reddevil6
  • 1673 Answers
SOURCE: my Bissell ProHeat 1699
There should be a black oblong gasket that sits between the edge of the noozle and the lip of the tank, If it is missing, then you will have to suction there. Also there should be a plastic red filter, mounted on the tank lid, covering the suction port, it it is clogged, then no suction.
Posted on Sep 01, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissel 7920 Diverter Valve Install
With the top cover off, turn it over, put the knob in the water only setting, the piston will fit in the slot (only one way), turn the knob some so it will stay on. Put the cover back on, but just before you push it down, turn the knob to the water only setting again, then push the top cover all of the way down. Turn the knob, you can feel if it is in the chamber or not. If not, it won't turn or be hard to turn.
Posted on Sep 18, 2008
  • 39 Answers
SOURCE: bissel pro heat carpet shampooer 1699
Push the foot pad handle release on the left side lay the handle all the way back.Then lift the handle on the center bucket pull out and fill with hot tap water only no soap in the hole that fills up the plastic bladder.Flip the handle back down so that it locks the lid on. On the right side is a smaller soap tank just pull it up and unscrew the top and put your soap in it then replace.Set the dial right beside it to either water only ,or high traffic or ,regular.The soap dispenses automatically saving you from having to mix the solution.Turn both switches on and make a forward and back pass holding the trigger release the trigger go over the area just soaped until most of the water is sucked up. The little red circle on the left side is supposed to be turning if the water and soap are being sprayed out.Repeat and have fun
Posted on Jul 01, 2009
SmartAlec
  • 171 Answers
SOURCE: Need Diverter Door for Bissell ProHeat 8910
HI there SmartAlec from NelsonVacuums.com.au here. I am an australian service agent for bissell. If you go to my website and use the link to put in a request I can get the parts for any Australian bissell machine. Your question doent give your location so i am not sure if this is a help or not.
Regards Alec
HAPPY VACUUMING :)
Posted on Feb 21, 2010
How do I hook up my Bissel Proheat to clean my sofa?
There is a little switch on the side of the machine base that reads "floor cleaning" and "toos or preheat". Switch that to the tools setting and a little flap under the "clearview" shield will lift. Just take the hose off of the little rack and attach one of the cleaning heads. Check that the flap isn't blocked by lint or something. If this doesn't work you may have some other problem.
Sep 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell manual
Sorry this is as close as I could come...but *** covers the Quicksteamer 1970 model...and surely it is the exact same process for yours...as this manual covers several models.....I found it at www.bissell.com.....I hope this helps...good luck and thanks For rating my effort....The Fang
http://www.bissell.com/images/UserGuides/1770_0206.pdf
May 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
Need full manual for bissell pro heat 1699 upright clearview
you can download it from bissell.com. The link below will take you to the 1699 page, this has a link for the full manual.
good luck
http://www.bissell.com/Product_Search.aspx?Criteria=1699
Aug 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
My Bissell ProHeat 1699
Aug 20, 2008 | Bissell 1699 ProHeat Clear View Upright...
My bissell deep cleaner wont release water and cleaner into the flow indicater
do you mean the little red spinning thing?try unscrewing the clear cover , lift the red thing out and check for hair etc.then put it back together. worked for me, hope it helps.
Jul 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View uses very little soap.
The valve at the bottom of the soap tank may have gone bad, Also try running a mix of water and vinegar(not on carpet) to see if it will clean the system out. The system may just need cleaning out.
Jun 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat Clearview water problem
The water comes out the hose at the same time. The diverter only diverts the suction from floor to attachment. If it is constantly spraying there is a problem with the attachment. Is it not spraying on the floor?
May 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
61 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
