Question about Kitchen Ranges
Controls on a GE Monogram vent hood ZVC36L1SS working randomly. How can one determine if it is the PCB or the switch assembly?
  • Ion Stancu Jan 07, 2013
    Here are some more details: the 5 control buttons (on/off, lights +/-, fan +/-) work sometimes; most of the times, they will not respond when pressed, and when they do, random things happen, i.e., I press one of the light switches and the fan starts, or I press one of the fan switches and the lights come on, etc. It is quite random, but to get them to work at all requires a higher and higher number of pushing ther buttons. I have taken apart the control switch assembly to look for cold solder joins but cannot see anythying obvious. To replace the switch assembly costs about $170, the PCB is about $300. This is why I would like to know which part to order and replace. Thank you in advance.
catriver
  • 878 Answers
SOURCE: ge monogram hood has power but not working
Diana, the tech sheet I have states that if the unit has a power interruption, reset the house circuit breaker to the hood, if made before 2001. If after 2001, serial number beginning with DA press the start button to reset the hood. Let me know if it worked, Catriver..post back.
Posted on Mar 10, 2007
  • 4102 Answers
SOURCE: Replace Broan Model K260A Range Hood Light Switch Slider Assembly
Hi if the new part has no screw holes or place for clip and it is only push in connector ie you dont need to solder the wires to it then it will just pull out use a small screw driver under the edge and gently pry free you cant damage it anymore than it is anyway can you.
Also on the side of the new switch if their is no groove cut into it for a push on clip to hold it in place then it will just pull out and push the new one in.
Posted on Jan 30, 2008
SOURCE: ZV30SSF GE Monogram Hood Lighting
I found them at http://lightbulbsdirect.com look for
MR1650E26120
JDR Type Medium Base (E-26) / MR-16 2 Diameter Flood / Line Voltage / 50 Watt, they were only $5.99 each. apparently GE charges you $19.50 if you order through them.
Posted on Feb 17, 2008
I have the same problem, only worse. The fuse is in the stack above the motor. You have to remove the vent decorative cover (that stainless tube that goes to the ceiling) and the fuse is in the low voltage circuit close to or inside the gray box that looks like a transformer (on the left). Mine blew out and I replaced the fuse, which lasted for about two months. I replaced it again and it lasted two days. Then, I replaced the triac with an NTE5679 (over on the right) (replaces ECG5679) about two years ago, and the fuse lasted until today. I do not know what to do now. We did not touch a switch just before the fuse blew. The fan was not running, but the lights were on. I think I will try a slightly larger fuse, but first I may look at replacing the fuse with a breaker that I can install behind the filters, instead of removing the stack cover every time the circuit goes out. Good Luck to you.
Ravenhaven
Posted on Apr 14, 2009
  • 10865 Answers
SOURCE: where is the fuse located in a ge monogram hood
there is a black electrical connection box inside the hood which contains the electrical feed, connections and the fuse which is a WB02X10584, rated 8A 250V. Remove the fuse, take a look to see if it is good [wire still intact] or check it for continuity and reinstall it if is good. Just removing it and reinstalling it is usually enough to have it work. regards, Joe
PS please rate my answer. Thank you.
Posted on Jan 16, 2010
I have a 2009 gmc sierra, where is the wiper relay location.
The PCB wiper relays are soldered directly to circuit board inside the under hood fuse box.
The windshield wiper/washer switch signal circuits are inputs to the body control module (BCM) and the BCM controls wiper motor low speed operation, washer pump and high speed operation. The windshield wiper/washer switch is provided a low reference from the BCM and each of the switch signal circuits is supplied 12 volts through a resistor and monitored within the BCM. During LOW or INTERMITTENT operation the wiper switch low signal circuit is closed to the low reference circuit through a series of resistors within the switch assembly and the signal circuit voltage monitored by the BCM will depend on the switch contact location to the resistor assembly. During HIGH or WASH operation the high and wash switch signal circuits are closed directly to the low reference circuit within the switch assembly and nearly all the signal circuit voltage will be dropped across the BCM resistors. The BCM controls the wiper motor through the WIPER CONTROL PCB Relay and the WIPER SPEED PCB Relay. During any wiper motor function that uses low speed the BCM supplies the voltage to energize the WIPER CONTROL PCB Relay and battery voltage will be supplied from the WIPER CONTROL PCB Relay through the de-energized WIPER SPEED PCB Relay to the wiper motor low speed control circuit. During high speed wiper motor operation the WIPER CONTROL PCB Relay is energized as in low speed and the BCM provides a ground to energize the WIPER SPEED PCB Relay and the battery voltage is supplied to the wiper motor high speed control circuit. Wiper motor park operation is controlled by the BCM using an input from the park switch within the wiper motor assembly. The BCM supplies the park switch signal circuit 12 volts through a resistor then monitors the circuit. Whenever the wiper motor is out of the park position the park switch signal circuit is closed to ground and nearly all the signal circuit voltage will be dropped across the BCM resistor. When the wiper switch is turned to the OFF position while the wiper motor is somewhere in mid-cycle, the BCM will continue to operate the motor until the wipers reach the park position. If the ignition is turned OFF while the wipers are in mid-cycle, the wipers will stop immediately where they are and the BCM will park the wipers the next time the ignition is cycled ON.
DTC B3715 02: Front Wiper Relay Drive Circuit Short to Ground
DTC B3875 00: Wiper High Speed Relay Circuit
DTC B3922 00: Front Wiper Function Select Circuit
Have it checked for DTC'S - diagnostic trouble codes .
The body control module (BCM) controls the wiper motor based on input from the windshield wiper washer switch. The BCM monitors the wiper washer switch through three separate signal circuits and a ground circuit. The windshield wiper switch high signal circuit is used to determine high speed wiper operation, the windshield wiper switch low signal is used to determine low speed, intermittent, and mist operation through the use of a resistor ladder, and windshield washer switch signal circuit is used to determine washer operation.
The BCM controls the windshield wiper motor through two output controls, controlling two relays which determine the desired wiper speed, high or low.
Your best bet , take your vehicle to a qualified repair shop or dealer . Hooking up a factory scan tool to see what the wiper switch inputs to the BCM are correct and outputs to relays are good .
Feb 11, 2017 | GMC Cars & Trucks
Ge hood insert zvc36l1ss fan comes on by itself. When not cooking?
The switch is bad. That makes it a possible fire or electrical hazard.
You should replace the switch immediately, or at least turn off the breaker that supplies power to the unit.
Don't let a broken $20 part be responsible for burning your home to the ground, fix it!
Parts for this hood are at http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Range-hood-Parts/Model-ZVC36L1SS/0432/0122400
This shows you how to open it up and replace the parts: http://www.searspartsdirect.com/partsdirect/user-manuals/9235/ZVC36L1SS-GE-Parts-RANGE+HOOD-manual?pathRender=fromManualTabPage
Jul 26, 2014 | Microwave Ovens
Diagrams monogram zv750s
Go to the G.E. Website and the diagrams there.
Jul 06, 2014 | General Electric GE Monogram 36""...
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram fan dying slow death...first hi-spd. only, now only humming, lights work...is it fuse, transformer or worse, blower assembly
My best guess is the blower motor is going out -- probably the bearings. You might be able to replace just the motor excluding the propeller or the squirrel cage as the case maybe.
Oct 08, 2012 | General Electric GE Monogram 36""...
GE Monogram 48" Freezer light works randomly
About the only way to determine what is causing the intermittent lighting to your freezer is to do a little electrical testing with a multi-meter. Also to press the door light switch in and wiggle it around may help you locate a bad door switch that simply can be replaced if the light decides to come on only when the door switch is pressed and released a certain way. Click here=> GE_Monogram_Refrigerator_Service_Manual Fresh Food and Freezer Light Diagnostics begin on page 46 of the PDF. I will be here if you have any questions but most of the physical testing will need be done from your end Testing the bulb sockets for firm connections and a good steady 12 volts output and 120 VAC input. If helpful please rate, Thanks, Sea Breeze
Feb 21, 2012 | GE Refrigerators
GE Monogram Wall Vent zv750SY blower Problems
javascript:launchURL('/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00035500/00035520.p01.pdf')
Jan 29, 2008 | GE ZV750SY Kitchen Hood
Kitchen Ranges Logo
165 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
