Question about Tablets & eReaders
Usb slipped into tablet and now can not connect to keypad or charge it
    New Friend:
Take it to a repair man i believe if u take it apart yourself you lose your warrenty most electronics havea seal on the inside so they can tell if you messed with it
Posted on Jan 04, 2013
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Jun 29, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
My tablets charging connection has slipped farther into tablet, how do I fix this?
The USB connector is a weak link in tablet construction. Usually it is just held in place by the solder although sometimes there is a bit of glue dabbed on it for strain relief. Most low cost tablets are not worth being repaired by a technician, so if the connector is still working, you could try to pull it out to the proper alignment and squirt a little crazy glue in to hold it in place. If the connector is not working, toss it in the recycler and buy a new one. And buy the extended warranty.
Apr 12, 2015 | Tablets & eReaders
Can I charge my Novos 7inch tablet through a usb cable attached to my computer there seems to be a problem charging through normal port
There are only so many milliamperes available to the whole USB bus on any computer. Having too many devices connected will cause not enough power to charge your tablet.
Try a wall adapter.
Mar 02, 2015 | Ainol Novo 7 Fire Android Tablet
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
Aug 24, 2014 | Tablets & eReaders
We got a RULU in 12/2013. It worked for 3 months and now can not charge i
Some tablet brands will not recognize certain charger brands or connections.
First, try all available connections-USB-wall inverter, and direct computer connection (making sure the computer is awake and logged in). Second, try restarting your tablet. Third, try gently wiggling the connections on both ends, to see if it recognizes a charge. Finally, leave it plugged in for a few hours, even if it says it isn't charging. You may have a trickle charge-to put it simply, the cord is not giving the device enough power to qualify as a charge, but there is power traveling through the cord. If the charge level goes up a little over that time span, you have a trickle.
If these don't work, just purchase a new charger. They're sold everywhere-Wal-Mart, Target, Best Buy, 7-Eleven, name a store and they probably sell USB charger cords.
I hope I helped.
Jul 08, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Aug 05, 2013 | Tablets & eReaders
Motorola xoom wont charge
this is very common/same problem lots people having with their tablets, but i recently found solution for it.... try the following.
first connect ur charger to the table as you normally would do for charging, then connect the tablet to the computer through the USB wire (make sure charger and usb wire both must connected to the tablet) and it should start charging.... this seem awkward but will 100% work try it and see it urself
Feb 03, 2013 | Motorola Mobility XOOM Android Tablet
Tablets & eReaders Logo
22 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
