Question about Radio Communications
I purchased a Cobra 148 GTL (made in Malaysia) that dosn't talk or recieve.
I have a Cobra 148 GTL (made in Malaysia). I have opened the case and found a green wire, that comes from the dynamike, that is loose from the mic pins. Also, there is a blue wire, that comes from the PC board at R246, that is not connected, either. And a grey wire, that goes into the board at R237, that is loose. If I could get a diagram of the wireing, not just a schematic, I can solder them back where they go. Also, the schematics, that I have found on the internet, have been for the Chinese and Phillipine models.
  • 10 Answers
SOURCE: No modulation in AAM only mode. Needing a schematic.
if the transmitter produces power output with modulation on SSB but NOT ON AM then the AM Pass Regulator is defective, more times than not.
Posted on Jun 10, 2009
  • 219 Answers
SOURCE: No regular 4 pin cobra mic will work on my cobra
switch 1 pin to 2 and 2 pin to 1. and 3 pin to 4 and 4 pin to 3
Posted on Nov 21, 2009
SOURCE: I need to know if it's possible to convert the
5 pin to 4 pin as follows, from the Cobra website.
1.->2 Audio
2.->1 Shield and common
3.->4 RX
4.->also goes to pin 1
5.->3 TX
Posted on Apr 26, 2010
Testimonial: "This is exactly what I needed. Thank you very much."
Ironfist109
  • 3018 Answers
SOURCE: i need schematics for cobra 148 gtl
  • When you get to the link click on "Click here to start download from MediaFire.." and the PDF will download onto your computer.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Oct 13, 2011
Ironfist109
  • 3018 Answers
SOURCE: schematic diagram of cobra 148 gtl cb radio china made
  • Locate the MB8719 chip that is right behind the channel selector. Wire a SPST switch from pin 10 to ground and another from pin 11 to pin 12.
  • Channel Chart
  • Position 1: sw1 down, sw2 down
  • NORMAL CHANNELS
  • Position 2: sw1 up, sw2 down
  • 15=26.815 20=26.885 25=26.925 30=26.985(ch3)
  • 16=26.835 21=26.895 26=26.945 31=26.995(ch3A)
  • 17=26.845 22=26.905 27=26.955 32=27.005(ch4)
  • 18=26.855 23=26.935 28=26.965(ch1)
  • 19=26.865 24=26.915 29=26.975(ch2)
  • Position 3: sw1 up, sw2 up
  • 1=27.605 6=27.505 10=27.555 14=27.605
  • 2=27.455 7=27.515 11=27.565 16=27.475
  • 3=27.465 8=27.535 12=27.585 20=27.525
  • 4=27.485 9=27.545 13=27.595 23=27.575
  • 5=27.495
  • Position 4: sw1 down, sw2 up
  • 1=27.605 11=27.725 21=27.855 31=27.955
  • 2=27.615 12=27.745 22=27.865 32=27.965
  • 3=27.625 13=27.755 23=27.895 33=27.975
  • 4=27.645 14=27.765 24=27.875 34=27.985
Posted on Nov 09, 2011
148 gtl receive works fine transmit has no power
Have you checked the 2sc2166 or the 2sc1969? Those are the RF Driver and the RF Final output transistors.
Jan 07, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl d has problem transmiting with covers off. trying to tune radio up. was thinking I need to ground the chasis
I would say a bad or cold solder joint on board somewhere. Bad quality control. Might flex radio chassis slightly while keying? A tooth pick and hours of probing around switching area on board and the pa section till problem found.
Oct 25, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Need assistance on finding how old an item is..
Where the unit was made is a good indication of how old it is. If it was made in Taiwan it is real old. Philippians is after that and Malaysia is the newest.
Other then that you can contact Cobra directly for them to look up the serial number.
Cobra website.
Jun 06, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Why does my cobra 148 GTL CB give out a squeeking noise when i trasmit as heard by others receiving me ??
is this a new radio? if so then the voltage change on the vco/pll will cause a squeak. kindda like a cobra 19dx does. also like the old golden eagle squeal .. all due to the voltage being unstable.. now is it that prob or do you have talkback and its loud/bad grounds causing a squeal. that could be the case too. if you have talk back let me know there's a cure for that. contact us..we can put the talkback just lil outtaphase to stop 99% of the squeals in cobra/uniden chassis radios.
Dec 11, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Have a new cobra 148 gtl took out of box no transmit or recieve
make sure that your [swr] hadn't changed or went higher than a 1.5, anything higher will interfere with your tranmitting an recieving. other than that with out being there to see an hear your radio this would be the first place to start.
Apr 25, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl b no recieve
make sure that the rf gain is turned up all the way.Check diodes D-12&D-13.
Jan 08, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl
Open the radio up and find the L22 Can/Pot. It's the one with the wire soldered on top. With both fine and coarse Claifier/Voice Locks in the 12 O'Clock positions, confirm, then listen for someone that is on the correct frequency and turn this pot (small ferrite core inside) with a small plastic preferred screwdriver, until they sound clear. Do this for USB as well except, the Can/Pot is L59. Don't adjust the VR5 (transmit) unless you need to.
Oct 06, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
78 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
