Question about Mitsubishi Da-g108 Stereo Graphic Equalizer
Graphic equalizer how to connect for my turntable to work with it
  • 1 more comment
  • Jim Meyd Jan 04, 2013
    Daniel here is the problem because I thought the same. The equalizer has preinstalled input and output connectors. I have no way of connecting my turntable directly to the equalizer because it also has a preinstalled output cable. The equalizer is a Mitsubishi DA-G108 and the turntable is a 1976 Technics SL-1300. Both items are of the same vintage, so I don't know why they aren't compatible.
  • Daniel Bakewell Jan 04, 2013
    on the record deck there are two phono plugs? red is right the white is left and there is a common ground black wire. What is there on the equaliser?
    according to the picture i have they are two male phono's as well, in which case buy a joiner?http://cpc.farnell.com/techlink/710931/2...
  • 691 Answers
There should be the connections from the turntable connected to the input of the equalizer then the output of the equalizer to an amp
Some turntables require a preamp so refer to your turntable manual.
(Some equalizers act as a preamp) You wont hurt it by trying it.
Posted on Jan 04, 2013
ION Max LP turntable connected to Onkyo TX-SR604 Home Theater
Use a different, brighter sounding cartridge and/or use an equalizer to bring the sound up to your expectations.
Jun 21, 2016 | Audio Players & Recorders
Studiomaster manual
On the rear panel there are two jack socket marked: Left and Right Insert.
These are connected to the graphic equalizer using two insert cables, one for each channel ( L & R). The cables have a stereo 6.35mm jack plug which plugs into the mixer, the cable splits into two mono jack plugs marked tip (or send) and ring (or return). The send (tip) connects to the input of the graphic equalizer and the return (ring) connects to the output of the graphic equalizer. How it works: The stereo jack interrupts the signal in the mixer and sends it to the equalizer, the equalizer processes the signal then sends it back to the mixer. Typical cable is shown below. If the equalizer has a different type of socket, phono for example you will need jack to phono adapters or insert cables with suitable plugs. Hope this helps.
Apr 05, 2014 | Audio Players & Recorders
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
My turntable is hooked but it wont work.
Bog standard TT connected to a bog standard receiver. Hmmm.
I cannot figure out where you have the equalizer placed (or why, but that is another topic).
What exactly is beeping?
Jan 24, 2013 | Sony PS-LX250H Turntable
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
May 17, 2010 | Audio Players & Recorders
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
We took our separates system apart to move it and know we cant remember what wire goes where at the back!!! we have turntable, equalizer, amp, cd player
start with the most basic ie; your amp is the recipient for all your cables so start with the cd cables into the cd phono inputs, then the turntable to the phono inputs. finally, your graphic into either the auxillary phonos or alternatively into the tape 2 phonos. good luck.
Sep 06, 2009 | Technics Audio Players & Recorders
No sound from speakers when turntable playing records
hi,, please check your RCA cable...or replace it possible...
Mar 12, 2009 | Aiwa PX-E860 Turntable
Conect eq. with the turntable
hi there, first you have to pit your turntable phono at the pre - amp phono to amplified then after you can put now direct into your equalizer and then to your amplifier
Dec 30, 2008 | Spectrum Technical Hifi EQ-B5200...
Mitsubishi Da-g108 Stereo Graphic Equalizer Logo
427 people viewed this question
Top Mitsubishi Audio Players & Recorders Experts
richie46
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
