Question about Cambridge Soundworks SWBE SoundWorks PC multimedia speaker system Speakers - Aud Computer Speakers
Replacement part or schematic for Cambridge Soundworks computer speakers
Hi, I need to replace the bass level control, but can't be sure which potentiometer will work best. CSW was no help at all. The part is labeled "TB50K Y", but form my research the naming convention may have changes since 1995 when this was manufactured. Actually I think any 50kOhm potentiometer might work, though the same type (linear or audio taper), and it must handle enough power. Thanks/Paul
  • Paul Suchma Jan 11, 2013
    My biggest concerns are power rating and physical fit. I am assuming that .25W would be enough, but will go larger if I can. From my investigations I think that the "B" in the name means it's a linear taper pot, though I don't know how much difference it would make if one used an audio taper. I am trying to find a place where I can actually see this widget, or at least see a list of its dimensions. As to bending the pins, I suppose this would work unless you break them or leave one in a "stressed" position there is might break later. So a little bend, OK, big bend, dicey.
  • Cosmo Lee Jan 11, 2013
    Hmm, that's good to know about the taper issue, I was wondering about that too. On the page I posted the link to, there is a link to the "Datasheet" which has the dimensions of the item. 1/2" square like the original, though the pins seem slightly short and the shaft is smaller in diameter. Would you say that the original is "cermet" or "conductive plastic" material?
I'm in the same predicament! I found this - it seems close, though the pins seem to be spaced closer together, but it looks like they might be bent to fit the wider PC board spacing. The rotating shaft also seems smaller - the original is larger than 1/4".
What do you think?
Posted on Jan 11, 2013
    Oops, I forgot the link: http://www.alliedelec.com/search/product...
  • Cosmo Lee Feb 24, 2013
    OK, it worked! There are a few things to be careful of: a) the threaded shaft which the strain relief nut screws onto is larger than the original part. I therefore needed to enlarge the external hole so that it would fit. b) You need to spread the connector legs to fit the PC board hole spacing, but I was able to do so without breaking them. c) There is a metal plate that fits over the aforementioned threaded shaft - its hole must be modified to fit over the larger shaft. I think it may be for static drainage or grounding. I simply left it off - the system works fine. Good luck!
5 Suggested Answers
  • 18 Answers
SOURCE: speakers working, then suddenly not...
It's possible they've died, have you checked that your sound card and drivers are working by using another set of speakers or headphones.
Posted on Jan 13, 2007
Open SKy
  • 619 Answers
SOURCE: Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Posted on Nov 26, 2007
kevin000
  • 1847 Answers
SOURCE: Hi. I cannot setup the
What is the exact problem you are facing?
Thanks
Kevin
Posted on Apr 27, 2009
  • 62 Answers
SOURCE: I found my ten year old pc works cambridge
1st make it sure the volts of your speaker...buy same volts power supply according to you speaker ..
example: 12v 1.0 ampere safe...
Posted on May 25, 2010
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
Jan 05, 2016 | Audio Players & Recorders
Service center philippines
I am going to guess these are fairly old speakers. I would recommend getting a replacement system.
Mar 22, 2014 | Cambridge Soundworks Audio Players &...
Can one fix remote control for Cambridge sound model 88?
Take it to a Tv repair shop to see they can do something, solder connections become bad, and may need a touch up.
Mar 31, 2012 | Cambridge Soundworks Soundworks 88 CD...
I have used the sound test to check my CS 5.1 system. When I test the subwoofers, there is no sound. I have played CDs with deep bass, no sound is emitted from the subwoofers. I have T-500...
One step at a time. Get the subwoofer to work, THEN play music through it.
You don't describe the electronics, IF you have a sub defined, whatever other steps it probably needs to pass LFE to the sub.
Register and download the manual for free at retrevo.com
Page 7
http://www.retrevo.com/support/Cambridge-Soundworks-T500-Speakers-manual/id/522bh631/t/2/
Apr 29, 2011 | Cambridge Soundworks Newton Series T500...
My Cambridge Soundworks PSW 12"
Take it out and look at it if you're going to replace it anyway.
or
Get a whole new speaker for cheap...
http://twintiers.craigslist.org/ele/2281123193.html
or
Call 800 376-4434 USA or 800 525-4434 Canada for factory assistance. (It's printed right on the back.)
Apr 20, 2011 | Audio Players & Recorders
Hi. I cannot setup the Cambridge Soundworks DTT2500
Thanks
Kevin
Jan 31, 2009 | Cambridge Soundworks CSW DeskTopTheater...
Hi Paulus
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
Cambridge Soundworks SWBE SoundWorks PC multimedia speaker system Speakers - Aud Computer Speakers Logo
346 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
