Question about GE Refrigerators
GE PDS20SFSLSS fridge clicking every few seconds
Returned from vacation to find GE PDS20SFSLSS fridge making clicking noise from the main board. I unplugged it over night and it restarted okay only to resume clicking after about a day. Unplugged again for a few hours and restarted okay but closer look noticed the fan isn't running. Is the likely fault the fan or the main board?
CMV9
  • 594 Answers
SOURCE: GE Profile PTS25LBMARWW - Power, but no Cold
yes the mother board is located under the plate in the back.. but when you replaced the relay did you put on a 3in1 relay or a manufactured relay?
Posted on Aug 01, 2008
SOURCE: GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Posted on Dec 13, 2008
aasc
  • 1606 Answers
SOURCE: ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Posted on Aug 06, 2009
SOURCE: Help w/ Refrigerator Compressor Overheating?
I had a similar problem yesterday (Maytag side by side unit 5 years old, however this apply to most brands). All operation seems normal other then that the refrigerator was not cooling, the air that was blowing inside the refrigerator was room temperature and not cold air. The compressor was also very hot to touch (could not touch it for more then 1-2 seconds) and didn't buzz or hum as in standard operation. I also heard few clicks from the compressor every time I plugged / unplugged the AC to the fridge. Replaced the overload/ relay device with a new one I got at a local appliance parts distributor ($30) and MAGIC. The unit went back to work as soon as I plugged the AC power. The relay/overload unit is on the side of the compressor and that?s where the electric wires are attached to. The unit turns the compressor on and off. The unit is attached to the compressor side with an "electric outlet" like three holes and three prongs. It might be held tight so you can pry gently (between the unit and the compressor body) with a screwdriver. Once pulled out, release the wires connectors that are attached to the relay/ overload unit. You might need to use pliers as they are tight fit. If unit smells like burnt or if you shake and hear rattle then it?s bad. Find a local appliance parts distributors and call to see if they have part for your model/ type. Remember to unplug AC before starting to work on the fridge and good luck.
Posted on Jan 15, 2010
SOURCE: GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Posted on Jan 18, 2010
LFC20770SW makes clock noise fridge not cooling
I have had a similar problem. In my fridge, i found 3 bad electrolictic capacitors in the main board. If you know how to dissolder, it is possible to replace them at low cost.
Get the refrigerator out of the power source and let it discharge. Find the main board casing and open it.
Check for stuffed capacitors. It is probably the ones that powers the relay. Or you can replace the whole board. There are videos on Youtube about it.
Refrigerator with clicking noise problem mp4
Jun 19, 2014 | GE GSH25JSRSS Stainless Steel Side by Side...
REPLACED MOTHER BOARD NOW FRIDGE IS WARM ON GE GSS20IEPJWW
You will need to check and make sure the main board is installed correctly and connections on the interface and main board are tight.
Jul 05, 2013 | Refrigerators
GE fridge fan clicks, ice dispenser not working
Main control board problem . Pt # WR55X10656 . The freezer fan motor , works off DC voltage . The board is not giving it enough voltage . The main board , also controls the dispensor board .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge makes a clicking noise fan in frezzer
Aug 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
The fridge is making a constant clicking noice
Had the same problem on my GE bottom freezer fridge. It finnaly died a few days ago. The clicking came from a relay on the main circuit board under a access cover on the back of the fridge. Ordered a new circuit card from GE ($157.50 + ship/handeling), replaced it, and the fridge works great. I have an electronics background but if you take your time and are safe, I think anybody would be able to change it.
Nov 28, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
I have a ge bottom freezer and now it is making a clicking noise and the temp lights are blinking in rythem with the clicking noise
Had the same problem on my GE bottom freezer fridge. It finally died a few days ago. The clicking came from a relay on the main circuit board under a access cover on the back of the fridge. Ordered a new circuit card from GE ($157.50 + ship/handeling), replaced it, and the fridge works great. I have an electronics background but if you take your time and are safe, I think anybody would be able to change it.
Aug 01, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
