Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung 46 DLP TV says "check cable" on all digital inputs.
TV was working fine. Switched HDMI from Playstation to cable box and a blue screen saying "Check signal cable" stayed on. Tried switching back to playstation with no change. HDMI no longer selectable as a source after power cycle. Composite cable doesnt work either.
  • 2 more comments
  • cvgranger Jan 19, 2009
    TV has been unplugged for over 2 hours and retried with same affect. HDMI cable has been replaced. Cable box has been replaced. Cable box and HDMI cable currently in use on new TV.
    Is this the part?
    http://tigerdirect.partsearch.com/Part/S...
    Would this affect only the input modules? The menu etc all seem to work fine. In other words, whatever is generated by the TV itself is displaying correctly.
    Its my understanding that the HDMI and component interfaces bypass the tuner completely.
  • Samsung Master
  • 19,396 Answers
With all respect for others' opinions I do not think you should replace the digital board ( http://tigerdirect...). without testing it, you risk to waste $200 or more on the wrong part.
When the D board is faulty the TV usually does not start up, and stays in safe mode.
I think the TV should be tested by a technician, you probably need to replace one of the capacitors located near to the HDMI connectors. They are easy to blow if you unplug and plug back HDMI cables when tv, or connected devices are on.
Call Samsung, using the phone number listed on the owner manual, and ask if a warranty extension is available. In case you will get an extra warranty, and cost is usually less than an average single repair.
Posted on Jan 21, 2009
  • 10,594 Answers
Due to some reason, firmware of TV inputs got stuck and its not being reset. In this case you need to replace Digital processing board.
You can buy it in Part Store for $219
Good luck.
Posted on Jan 19, 2009
    President:
  • 2,559 Answers
Check here
  • Randy Hough
    Randy Hough Jan 19, 2009
    Have you made sure it's not in shop mode?
    If not do this
    On the tv,Press (volume up) Once
    Pess and hold the (Menu) For about 5 seconds
    The menu will appear and then disappear,Then a dialog box will appear at the bottom of the screen that says "DYNAMIC" the tv is now out of shop mode.
    Scholar:
  • 62 Answers
Http://en.wikipedia.org/wiki/High-Definition_Multimedia_Interface
This has a lot of info for you I hope it helps. If it does not please give me the length of cable and type of HDMI you are using A,b,c
    Sergeant:
  • 221 Answers
Its the problem of the input socket of the tv where you insert the cable that socket is loose and had to be soldered internally by opening the unit of tv.as also try connecting any other external device in the socket and confirm the fault before replacing the socket.
  • 505 Answers
HDMI goes straight into the digital main pcb and this should fix the issue. You should contact samsung customer support and make sure there is not a software/firmware fix for this issue/other HDMI issue
  • Samsung Master
  • 4,806 Answers
Hi there
Use the remote to get into the OSD and reset the TV back to factory settings, you will have to use different sub menus to reset them.
turn off for 10 mins then select your signal source again
Good luck
    Genius:
  • 2,920 Answers
Isounds like the tuner went out on the set if its telling you no signal.with a blue screen. id say its probably a problem with the tuner
  • Ronnie Houston Jan 19, 2009
    not always true.my akai tv was going the blue screen and it ended up being the tuner and signal contrls,,it cost me 400 to get it repaired,thats why i think maybe its the tuner and or relater component
  • 124 Answers
Plug in the cable ps3 came with into tv and ps3 with ps3 on standby mode this is when red light is on hold the power button on system down for 10sec to switch the tv settings then when picture for ps3 comes back up plug in hdmi cable with the other cable attached and try to switch back to hdmi to see if it fixes your problem hope this helps you
  • chris ciraldo Jan 19, 2009
    also i know walmart has a 32in sony bravia on special for 599 i own one its a very amazing tv with tons of inputs if you were in need of alot and my solution dosent fix your problem and you dont wish to buy a $300 part you may also be able to find this tv for 499 in some stores
    try reseting the tv also
    The service menu is pretty well hidden behind a sequence of key presses on your remote. Here’s how to get in there:
    1. Turn your system off.
    2. Press the following buttons individually with a short pause between each: Mute-1-8-2-Power.
    The Television will turn on into the service menu. Once in there look in the Options menu for the lamp hours and counter reset. As for the other settings, I’ve never messed with them, and I’d caution against playing around there!
    this tv set has had many problems dont try buying all the parts it could be cheaper just getting a new tv i hope this helps
    Brigadier General:
  • 5,158 Answers
When you hooked them up... either to the playstation or the cable box... were they on at the time ?
Robert
  • Roberta Smith
    Roberta Smith Jan 19, 2009
    They may do that but you may also have to swtich to AUX to make it work... hence the no signal problem
    Robert
    Scholar:
  • 160 Answers
It shows if the cable is not connected properly or the cable is slightly got cut in between so for that replacing the cable is necessary. get the replacement cable from  www.bestbuy.com and it will work properly after that thanks.
    Scholar:
  • 87 Answers
This unit appears to be affected by a possible software conflict.Disconnect the A/C input from the wall for an hour or so tho reset system.If this does not work I will provide you with main bord part number.
  • 4 more comments
  • Albert Vasquez
    Albert Vasquez Jan 19, 2009
    To provide you with the proper main board number and proper diagonsis I will need the software version number on the side of the unit.There is a sticker on the left side of this unit with the model,serial and version numbers.
  • Albert Vasquez
    It appears you have a defective main board.This part is not servicable.Part # BP94-02065A with a cost of about $300.00 depending on wher you can order one from.That price is the price us Samsung service centers pay.
  • Albert Vasquez
    I`ve double checked my previous response on this unit and the main digital board indeed is the culprit to this problem.Your component and HDMI inputs both are processed through the main digital board.I am curious though.Do you have analog tuner functions and composite video(yellow input), menu volume bar ,and do the buttons, and remote respond?This information will give us a definite.
  • Albert Vasquez
    Yes it will affect the 1080I inputs for sure.I work on these things all day long and as an Authorized Samsung Service center I would suspect the main digital board.This is only if the analog tuner is working.
  • Albert Vasquez
    Yes that is the part.
  • Albert Vasquez
    Yes the HDMI bypasses the tuner.You don`t have a tuner problem.The tuner has nothing to do with HDMI.As I asked eairler do you have tuner function.The tuner does not bypass the digital board,nor does the,composite video,s-video,component, or VGA,all video runs through the digital board.The menu and all on screen display are generated through the analog board but from a diffrent part.It has a path all its own.
  • 837 Answers
Have you tried unplugging for 10 minutes or more?
Has audio, but why did screen go black?
since the self generated menu displays ok id say you don't have a monitor problem , could it be that maybe somehow it got switched over to maybe an "open" input port (example: hdmi-2) as this would explain things a bit , also when you tried the other tv did you use the same cables to connect it as the non working tv ? as that also would explain things
Feb 09, 2016 | Panasonic Viera TC-P46C2 46" Plasma HDTV -...
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Hdmi inputs are not working on my mitsubishi WD65738 DLP
That TV is suppose to have automatic input detection but if it doesn't work you can press the input button on the remote and then use the arrows and enter to select the input you are trying to use.
Dec 12, 2013 | Mitsubishi WD-65738 DLP TV
Keep getting a blue screen. Avery so often the picture switches to a blue screen and than picture comes back and than a few minutes later a blue screen. Thank You
Sounds like a problem with source recognition. Could have a problem with input coming into the tv such as cable connection problem, loose wires, etc. Try reseting the cable box and removing and reinstalling all of the cables in the back and the cable box.
Oct 01, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
Samsung HL 61A750A1F
The Samsung Television has 3 HDMI inputs, You would connect an HDMI cable from the Cable box to your television and go into a menu on the television to select the appropriate HDMI input.
New cable boxes should have the HDMI connection.
Most Flat screen televisions I've seen have an input button on the television itself. Pushing it should allow you to switch between inputs.
Sep 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-R6167W
Most likely the digital board will have to be replaced. Not a cheap part, so you might concider using the component inputs for now if too expensive.
Jan 23, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung Rear Projection DLP HDMI Captions
The captions are turned on in the cable box itself. If you have a Motorola cable box, turn it off then hit the menu button for the cable box. You will then see where you can turn off the closed captioning. Anymore questions email me tvtek@msn.com
Nov 29, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
