I have a whirlpool lsr7333pq0 and my cold water quit working i get hot water just fine. There is also no sound comming from the machine.
  • 61 Answers
Turn of the cold water disconect the cold water hose from the washingmaching look inside the valve where the hose conects you will probably find a build up of sand or dirt of some sort with a small flat head screwdriver remove the screen from the valve rince it out the reinstall reconect cold water to machine and turn on. Now check operation of machine. let me know if thisdoes not fix the other problems that could cause this will be a little harder to check.
Posted on Jan 19, 2009
My Whirlpool Duet Washer #GHW900LW1 does not pull the hot water.
Sorry this answer is about 1 month late, but in case you're still having the issue, it is likely due to 1 of 2 possibilities (or combination of both).
Most likely, the small inlet screen, located on the back, (where the hot water hose enters the machine) is clogged. This is a common problem that restricts the flow of hot water into the machine.
To check or clean this, just unscrew the hot water hose where it enters the washer. It sits just inside that fitting.
The other possibility is a bad or clogged inlet valve. The inlet valve controls the flow of hot and cold water into the machine. It is opened and closed via an electric solenoid (part of the intake valve unit).
The inlet valve is the same unit that houses the screen I previously mentioned, and is just inside the back panel of the washer, where the two inlet hoses thread onto.
Oct 06, 2014 | Whirlpool duet Washing Machines
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
My washer wont run in the hot water cycle
Sounds to me like your water valves in the back are going bad, just had it happen on mine the other day, I bought one online for like 15.00 that was new solinoid valves for both hot and cold water. took about an hour to install with no instructions (take the old one out, new one hooks up the same way) or call the washer repair people.
Mar 18, 2009 | Whirlpool Washing Machines
LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Mar 18, 2009 | Whirlpool LTE6234D Top Load Stacked...
Ge washer
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 26, 2008 | Whirlpool GST9679P Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
