Question about Konica Minolta DiMAGE E500 Digital Camera
LCD is black
I went to turn on my camera and everything turned on normally( shutter opened). When we lookied at the LCD screen it is black but the icons show up. We can review past pictures taken and change setting. If you take a picture the way it is now the picture turns out black.Help!
  • sairaghav Aug 23, 2008
    the lcd blacks out wen i want to take new images ... im able to see previous images taken in the lcd . All other functions are working perfectly !!
    please help me....
    Genius:
  • 2,985 Answers
You can see images clearly? but no Menu items show is that what you mean? This would indicate a firmware malfunction. If you see nothing at all on the screen but only 'ghost' images then the back light has blown. Try first of all with the camera on tapping gently at the base of the casing in the region of the screen- this is where the connectors to the main board are. Contact The Minolta support team. If you are getting nowhere - I suggest the next camera - repairs are not usually an economic option if at all.
Posted on Jun 27, 2007
SOURCE:
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
Camera works but the screen went black A640 except for video and color swap. Did I press a button? I was shooting in cold weather.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
But if you've already tried this, have you also tried downloading any of your photos taken with the black screen to your computer? Are the photos also black? If so, you might instead be experieincing a stuck shutter (possibly due to the cold weather).
Jan 03, 2010 | Canon PowerShot A640 Digital Camera
Problem with canon a420 digicam
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
Black LCD screen on canon powershot S5 IS
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Aug 11, 2008 | Canon PowerShot S2 IS Digital Camera
My lcd screen is black
hi there guys, if the screen is black and the camera takes black pictures, then you should look if you are getting a on screen display on camera mode. if you are then i would say one of two things, either the shutter is not opening or the ccd( electronic imaging device) is not functioning. to check the shutter you should look into the lenses centre part and check for movement from the shutter to see if it is opening.
Jun 06, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
LCD Black
Contact Damage support - there appears to be a problem with this model
http://www.google.co.uk/url?sa=t&ct=res&cd=1&url=http%3A%2F%2Fca.konicaminolta.com%2F&ei=bzOwSMj2CYreQd-i-Gg&usg=AFQjCNEEQPR1zDRvdYe3DCF0EhXowwYetw&sig2=AAutefCXmdjtFGCFF7XjRg
Oct 26, 2007 | Konica Minolta DiMAGE E500 Digital Camera
Black Lcd and pictures.
The problem you are experiencing is due to the shutter being stuck closed. Normally the shutter is kept open while you compose the image, and then when you push the button it closes and the CCD records what it was seeing at that moment. When the shutter is stuck the image is blocked from reaching the CCD at all times so you can see nothing. Unfortunately the shutter is a tiny delicate component buried deep within the lens assembly and is not accessible without complete disassembly. I would suggest finding a repair center to ship the camera to, or replacing the camera. I would definitely not _gently_ tap the camera on a hard surface to possibly dislodge a slightly stuck shutter blade. This could easily cause further damage to the camera. However, you are not me. ;) David Millier Advance Camera Repair
Feb 22, 2007 | Nikon Coolpix S1 Digital Camera
LCD screen won't turn on and shutter won't open or expand.
It's probably in PC mode. It still thinks that it's connected to the computer via the USB. It should be somewhere in the set up configuration. If you can't get it to switch back to normal, disconnect it from all power sources(including internal memory button battery if present) in order to reset it. make sure you turn off the camera before disconnecting it from the USB. Good luck
May 30, 2006 | Casio Exilim Pro EX-P600 Digital Camera
Konica Minolta DiMAGE E500 Digital Camera Logo
140 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
