Question about Frigidaire FGQ332ES Gas Dryer
Fridgedare front load dryer wont start, no noise, the light is on so i know it is getting power. finished one load went to start another and turned the switch and nothing
Model number sxd74507081
  • Official Brand Answer
  • 4,342 Answers
Hello ebega7 - I understand the lights are blinking; however will the display illuminate or allow you to program a setting? If it will not allow you to do so, try resetting the unit by either unplugging it or flipping the household breaker off. Wait approximately ten minutes and turn on the dryer. Select a normal cycle and if it is ineffective contact a professional to move forward accurately. The unit may possibly have a defective cord or wiring, control board or door switch.
Posted on Jan 08, 2013
ngfam1
  • 639 Answers
SOURCE: figidaire front loading dryer
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Sep 02, 2008
thaurfen
  • 623 Answers
SOURCE: Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Posted on Jan 08, 2009
  • 130 Answers
SOURCE: dryer wont start
its one of three things, check your thermal fuse on the back inside of the vent, the door switch or the start switch
Posted on Jan 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: my Frigidaire dryer makes a banging noise
What you have here is a drum bearing issue. Read my award winning essay on this subject right ova HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 09, 2009
  • 36 Answers
SOURCE: my front load dryer model number FEQ1442ESO is
an internal thermostat called a snapstat and/or your heating element and/or your dryer ventmay not be working or needs cleaning. you need someone experienced in testing with an ohmmeter to test and get back to us.thanks karl
Posted on Dec 02, 2009
Ge front load dryer wont start but all the lights work and you can pick a cycle it also makes clicking noise when you push start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | GE Dryers
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
When turning on the dryer it made a loud noise that went away as the dryer continued now the dryer doesnt always start but I still get the loud beep noise when the dryer is finished if that helps
heatman101
ytet87
Feb 10, 2010 | Kenmore 73952 Gas Dryer
I just finished drying a load of clothes in my hotpoint front load dryer; & now my dryer is just making a humming noise & won't start
Is this a repeat question?
Broken belt - pop the top - remove the front ... get a new belt - put it around the drum, through the tensioner and over the motor pulley. Reassemble.
Get belt at Fixya advertiser, local appliance parts place or www.repairclinic.com
Oct 20, 2009 | Dryers
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryer wont turn on
Ours was doing the same thing you would hear a click and nothing but the sensing light. I found the thermal fuse to be blown Part #3392519. Easy to get to through the front cover under the load door. I went ahead and vacuumed and cleaned out the inside and vent tube.
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Frigidaire GLEQ2152ES just hums when you start it... doesn't turn
Unfortunately, this is probably a bad motor, part # 131560100. It retails for $129 but can be found for around $100 shipped online. You can inspect for a clogged blower first by removing the front panel.
Dec 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
It wont finish washing
open and close the lid a few times. can you hear any clicking noises, you should hear the lid engaging the lid switch. if the machine doent think lid is closed it wont funtion( safety reasons)
Feb 27, 2008 | Maytag LSE7806A Top Load Stacked...
Frigidaire FGQ332ES Gas Dryer Logo
41 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
