Question about LG 1720B 17" LCD Monitor
Is the AI 0066 Rev G PCB interchangeable with AI 0066 Rev I ??
Rev G board is bad... I have purchased a replacement, it appears to be a Rev I. I'm asking if they are interchangeable.
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have a L1930b with a bad panel. I have a panel
You can use the 5vdc from the monitor power supply
Service manual: http://elektrotanya.com/?q=showresult&megnev=lg&megnev2=L1930B%20&kategoria=&kat2=all
I look at the diagram page 31, pin 1~3 is the VCC for the panel with notes for 12/5vdc, it can be connected to the 12 or 5vdc, so it must have a jumper on the board somewhere that will let you choose 12 or 5vdc for the panel, the main thing is that the rest of the panel pins match the original panel, please verify that first.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 09, 2010
I have an AquaLink control panel BH6100
see if wires are touching at 4 pin red connector if ok then check to see if wires to controller cut or shorted if all ok bad PCB board see if controller works next to aqualink using a cheater wire if ok bad wiring if still bad PCB board
Jan 22, 2015 | Pool & Spa
What can I do to use a PCB#6474G to replace a broken PCB#8124A?
yes the G is just a newer board go to set up and reprogram all your auxs just re assign them
Jun 15, 2014 | Jandy Aqualink RS4 Pool/Spa Combo -...
Samsung TV Model LA40A650A1M back light intermittently strobeing and sometimes cuts out completely, powering TV off via remote and back on temporarily resolves issue, but returns at various times, have...
You can't see if a cap is good or bad jus looking at them they have to be measured>They loose their capacitance because they dry overtime.
I do sugest that you replace you power supply module or replace all caps.Possibily you may have a broken line in the PCB
Sep 11, 2012 | Samsung Televison & Video
I have a non-functional Sharp LC-32D62U (32") TV.
It would be possible if you can go into service menu and write all settings and implement with the new board by going back in and changing what you wrote down.
Feb 17, 2011 | Sharp Aquos LC-32D62U 32 in. HDTV-Ready...
I have a L1930b with a bad panel. I have a panel that will fit this monitor but it is an LM190E03-B4, which takes 5V input, whereas the original panel takes 12V input. The power inverter is a Lien Chang...
Sep 08, 2010 | LG L1930B 19" LCD Monitor
No power with 700P LCD monitor, No green light, nothing. replaced 2 popped 470 25C caps. Nothing else looks bad. Board 860-ALZ-M713-F
You will need to check for any pico fuses that run along those capacitor lines they may be marked as pf or nf on the pcb
Jan 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Samsung HD 42inch TV Model No. PS42S5H Y Board
Your board numbers should start with LJ92. They will cross to both Samsung and LG. Oh, your model number goes nowhere, double check it.
Aug 25, 2009 | Televison & Video
Error E354 in copier ir2016
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Mar 26, 2008 | Kyocera KM-1505 Copier
LG L1715S TFT power issue
Change out C202- 680 uF 25 Volt electrolytic capacitor. Replace with 25 volt or higher. Observe proper polarity when replacing cap: (-) goes to the side with the black mark, check old cap before removing it to see. I just fixed the same monitor today.
Dec 04, 2007 | LG Flatron L1715S 17" LCD Monitor
LG 1720B 17" LCD Monitor Logo
90 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
