Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remote Controls will not work outside my house.The remote controls will not operate my Henderson Ultra garage door unless I stand right next to the receiver. The remote controls for my car will not lock/unlock my car unless I place the remote close to the drivers door. Both the garage door and car problem started around the same time and the car works fine when I am away from the house. Neither of my neighbors have a problem and all the batteries in the remote controls are fine.
3 Suggested Answers
  • 3197 Answers
SOURCE: Garage door opener won't work unless right on top of garage
The receiver is most likely going bad. It is part of the logic board. The other possibility is if you added anything electric to the garage. Some of the strangest things will interfere with the opener. If you added anything unplug it and try. Otherwise it is the receiver.
Posted on Jun 27, 2009
  • 3197 Answers
SOURCE: Craftman 1/2 garage door. Model 13953879. RF intereference issue
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range does not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Posted on Apr 19, 2010
I have 2 Merlin MR800 garage doors operating side by side. 1 door stopped working with the remote, however it WILL open the door if you hold it right next to the unit.
What kind of light bulbs are you using? I know it sounds crazy but the new LED and the old CFL can interfere with the range of the transmitter by blocking the signal to the receiver
Mar 21, 2016 | Building Materials
The klik3 works inside the garage but not outside the garage
make sure antenna wire is hanging loose and that the remote batteries are new
Aug 18, 2015 | Building Materials
Digidoor remote
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Jul 29, 2013 | Audio Players & Recorders
Sears garage door opener (GDO) model 139.53985D, only a couple of years old. 315MHz remote controls. Opener has stopped responding to the remote controls,unless a remote is held wihin 12 inches of the...
There is no way to change that radio frequency it is set by the government. Sears service technicians have an instrument to help them locate the interference that causes this type problem.
Oct 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Locked out & Remote not working
There should be a green button on the back of the motor unit, press it for 2 seconds and then hold down your remote button until the light flashs. or for 3-5 seconds and then activate the remote. that might solve your problem
Jun 29, 2009 | Chamberlain 950CB Remote Control
How do I re-code my Raynor Garage door opener Model 61 rdg (on Remote) Serial # 17592 (on opener) Year 1992? I am a new resident in the house with this garage door opener. The remote control opener worked...
on the back of your garage door opener there is a colored learn button--press and release-the learn indicator light will glow for a short time usually 30 seconds. within thirty seconds press and hold the buton on the hand held remote that you wish to operate your garage door. release the button when the motor unit lights blink. if you don;t have a light, two clicks will be heard. it has learned the code. procedure will be different for multi function control.
Apr 03, 2009 | liftmaster Chamberlain Garage Door Opener...
REMOTE CONTROLS WILL NOT WORK-WALL BUTTON FLASHING RAPIDLY
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
55 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
