Question about Pentax K1000 35mm SLR Camera
Pentax k1000 film advance lever flip stuck open
The little silver flip open lever is stuck open. I can still rewind load etc but flip is in open position and will not budge. I am afraid to force it as it may break off. Help :)
3 Suggested Answers
poolseman
  • 206 Answers
SOURCE: Film advance lever
Yes this is fairly common with K 1000 and the Spotmatics : although the shutter is cocked and hence you cannot advance film you cannot release shutter because mirror box is not cocked. Remedy : remove bottom cover and locate mirror box lever which protrudes slightely and is movable up and down and is spring loaded. Move upwards until it licks in position ( moving up against spring tension ). Now release the shutter and camera should let you advance the film .
Posted on Sep 17, 2007
  • 102366 Answers
SOURCE: My pentax k1000 works great
I'm not sure I see a problem here. There is enough slack in the film that the first few exposures can spool out of the canister without it turning. If in doubt, close the back and then _lightly_ turn the rewind crank to take up the slack. Don't force it, just turn it until you feel resistance. Then advance the film and see whether the rewind knob turns.
Posted on Feb 28, 2011
Testimonial: "Thank you!"
How do you replace the rewind shaft of a pentax k1000 without causing any damage?
Open the camera film cover back.
Stick a flat blade screwdriver between the silver film sprocket, then turn the Film Rewind Crank out.
atdlee@netzero.com
Jun 25, 2014 | Photography
Advance lever and shutter stuck how do I fix it
Is there film in the camera? If so it may be at the end of the roll and thus when advancing the film it jammed. Rewind the film then see if the lever and shutter operate. If not then a CLA is needed.
Oct 28, 2013 | Pentax K1000 35mm SLR Camera
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
The flip up switch to rewind the film has fallen off, I have all the original pieces but cannot fit the bar in. How do I take off the rewind lever to fix it?
Perhaps the following site will help you visualize the fixing. I remind you that these film cameras sell for very little now days and can be purchased for a song. see: http://www.slideshare.net/lokerd/pentax-k1000-35mm-slr
Apr 14, 2011 | Pentax K1000 35mm SLR Camera
My pentax k1000 works great except for when I first load the film. Every time I first load the film, the rewind knob wont rotate when I snap pictures. Everything on the inside is intact and usually I have...
Feb 28, 2011 | Pentax K1000 35mm SLR Camera
When I turn the knob on the camera to be able to take another picture, the number still stays at zero. What's wrong with my camera?
There are a couple of possibilities that I can think of:
First, film must be loaded into the camera for the picture counter to increment.
Second, if you've loaded film, but the counter still does not change, it is possible the film is not advancing (the film release button/knob/lever that you use to rewind the film may be activated) or the film has slipped off the sprockets on the take-up spool.
If you can stand to lose the photos you may have already taken, just open the back of the camera and make sure the film is advancing when you take a photo.
If you can't possibly lose the photos, rewind the film and take the film to be developed. Try to find a local developer that only charges for the photos that "came out"... This can save a lot of money if only a few frames develop properly (or if none come out!)
Sep 01, 2010 | Pentax K1000 35mm SLR Camera
How do I rewind and take the film out of a pentax k1000?
mhamabrown,
push the rewind button on bottom of camera and turn rewind knob to the right, ( clock wise ) then pull the rewind knob up to open the film door.
Feb 24, 2009 | Pentax K1000 35mm SLR Camera
Film developing clear
Hello
This problem could have a number of causes,
To check to see if it is a camera fault of developing fault you could try using a cheap colour film in the camera and getting it developed at a normal photo processor.
This will determine in which half of the process the fault lies.
If the pictures from the colour film are the same then it must be a camera usage problem or fault.
If the pictures are ok from the colour film then it will be a problem in either the film being used, developing problem (poor mix of chemicals etc).
This will just speed up the diagnosis a bit.
Oct 02, 2008 | Pentax K1000 35mm SLR Camera
Film Advance Will Not move
Hi,powerpe. The mirror release rod can be located in the bottom of the body once the plate has been removed.(there are three screws on the old k1000's) There is a gear train on the left side when viewed turned over.The mirror cockong rod is towards the rear and a little right of the main shaft.You might need to move a little silver pawl with a pin or micro driver then you can push the mirror **** in to release the reflex mirror.the mirror cocking rod is about 1/8" dia.Hope this helps
Oct 21, 2007 | Pentax K1000 35mm SLR Camera
Film advance lever
Sep 17, 2007 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
