Question about Aqua Flo External Pump
Want to replace the seal on a water way SD-10-2N11CC
  • Aqua Flo Master
  • 1,631 Answers
Open up the pump volute/housing body, unthread the impeller from the motor shaft. then remove the seal & replace it. NOTE*** ensure that the round doughnut part, dark color, of the seal half (with the spring looking thing) touches the white part of the other half. Most people when changing the seal, believe that the rubber parts of both halves need to touch. that is WRONG. Reinstall and assemble everything back in reverse.
Posted on Jan 16, 2013
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Leaks from underneath
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Kenmore Elite Washing Machines
Cold Water Drips from Spout after shutting off
The spout's seal is not sealing off the water properly any longer. You can replace the seal if you are handy. It is a little tricky but comes with replacement instructions. You may be able to find the replacement part at Lowes or Home Depot. Regardless as to where it comes from, it has instructions. I hate to say this but I would rather replace the unit rather than trying to replace the seal. However, this type of unit is pricey and it is more cost effective to replace the seal. NOTE: Doing any plumbing work may require you to cut off the water supply to this unit. If you dont have shut off valves to this direct water supply, it may even require you to shut off the water to the home. Good luck.
Jan 20, 2011 | Jacuzzi Water Rainbow Tub Faucet ...
The paddle on my panasonic breadmaker has stopped turning. Without the pan the mechanism revolves but once the pan is in place the paddle does not move.
If you take the pan out of the machine and can't turn the paddle freely by hand, then the sealed bearing is frozen. You can try putting warm water in the pan and soaking it. After a few tries if it does not free up then the sealed bearing is broken and bread pan needs to be replaced. Good Luck..Hank
Feb 06, 2010 | Panasonic SD-YD205 Bread Maker
Milky oil on my wr450f 2004
your water pump seal and oil seal have failed on the water pump shaft. Replace both seals noting which way the seals face. replace the water pump shaft if it is scored. Chaz- Moto DC
Jan 20, 2010 | 2004 Yamaha WR 450 F
Lossing water out of small hole on under side of motor ? Normal or not
Not, sounds like a seal vent for the water pump, shouldn't leak.
Jan 07, 2010 | 2005 Honda CRF 450 R
04 yfz 450 water pump leaking from weep hole
you get the impeller of from removing the complete side case ( not only the water pump cover) then you can remove the water by unlock the internal water pump shaft....replace OIL SEAL
93109-11073-00 and also OIL SEAL,SD-TYPE
93102-12321-00 just to have you're mind in piece..they are so unexpensive that you d'ont wanna take any chance for 4.00 usd.....cfb12e5.gif
Oct 02, 2009 | 2004 Yamaha YZ 450 F
Proline pool pump SD-1--1N11XB
This sounds like you have a bad seal in your pump and the loose piece is probally a piece on the shaft of the motor called a water slinger. This is just there in case your seal goes bad and leaks water it will spin with the motor and sling the leaking water out and away from the motor so a small leak does not ruin your motor. But you will still need to replace your seal and "O" ring.
Sep 12, 2009 | Hayward 1.5 Hp Northstar High Performance...
Washer is overfilling
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Leaking water on floor in front of dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Aqua Flo External Pump Logo
80 people viewed this question
Top Aqua Flo Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Aqua Flo Garden Expert? Answer questions, earn points and help others
