Question about HP 15C Scientific Calculator
Have just bought a second HP 15 C calculator (the first one had a faulty 7 button) and when the ON button is pressed PR ERROR is displayed. Pressing buttons at random removes the error after which it works normally. It can be turned on or off at short intervals with no problem. However, if left off for a few minutes, PE ERROR returns when next turned on. I have performed the self-check procedures mentioned in the manual and box erratum sheet but these have not solved the problem. It's just a nuisance to have to trick the device into a working condition. Would appreciate any ideas - don't think I am doing anything wrong. Just a little disappointed in HP right now. Thanks.
oldnovii
  • 667 Answers
SOURCE: HP 32 won't work
Hey Dave- take a look at the following link. I like to have the user actually look at the user guide instead of describing it. If this solves your problem PLEASE rate this as fixed. If this isn't exactly right or you need more help just add a comment and I'll be glad to help you further. Thanks.
http://h10032.www1.hp.com/ctg/Manual/bpia5305.pdf
Jeff
Posted on Apr 30, 2008
  • 8016 Answers
SOURCE: Too few arguments appeat when turn on the HP 48gx calculator
This calculator uses RPN (reverse polish notation) not algebraic notation.
If say you want to calculate 12+13, you proceed as follows
12 [ENTER] 13 + : the claculator displays 25
Similarly
12 [ENTER] 13 x : displays 156
Also if you use a function like sinus or cosinus
12 [ENTER] cos displays the value (depending on the angle unit you are using).
I think you need to read a little more on the RPN before you get accustomed to this way of doing thing. The best reference is your calculator Getting started manual.
Hope it helps.
Posted on Aug 24, 2009
adnanbhatti
  • 1188 Answers
SOURCE: HP48GX Calculator "On" button works intermittently
The calculator battery may be weak. Replace 3 AAA cells and check if it works.
It is possible that sweat from your or someone else's hands hand leaked inside and dried up leaving a salt residue between the connections.
Remove the screws on the back panel to dismantle your calculator then use a piece of paper to clean the contacts between the top and bottom connector.
If you cannot get this done then take it to a watch repair shop. The person there can assist you.
Posted on Sep 09, 2009
SOURCE: the calculator, hp49g+, will not turn on by pressing the "ON".
Hi, if pressing on and F5 together immediately starts the selftest your keyboard is OK, but one of the capacitors on the HP49G PCB are broken. I replaced all three and the turn on/off problem was gone.
Hope this helps.
Joachim
Posted on Nov 20, 2009
  • 8016 Answers
SOURCE: My HP 48G does not come on.
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the begining of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
There is an HP customer self repair (CSR) which you can contact. On the site it is sais that the service is available for products under warranty or on contract. but you have nothing to lose by contacting them. Here is the link to the web site
You can also try this site. They do repairs on most models, except the newer ones.
Hope it helps and Thank you for using FixYa.
Do not forget to rate the solution.
Posted on Nov 30, 2009
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
The error message is Oxc18a0001. What is wrong with it. I've turned the printer off like it said to do, with no change.
Error seen on printers HP: HP Photosmart 7280, C5180, C6280, HP photosmart 8250...
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
May 06, 2011 | HP Photosmart D7460 Printer
HP12c showed expected display for low battery (star in lower left), put new batteries in and could not get any display at all. Took betteries out of mine (working great!) and now the one not working shows...
Resetting the calculator using the keyboardThe easiest reset is done from the keyboard. To reset the calculator, follow the procedures below in the order presented.
  1. Press ON to turn off the calculator.
  2. Press and hold [ - ] .
  3. Press and release ON .
  4. Release [ - ] .
  5. The screen will display “Pr Error
  6. The calculator will reset to the default settings, and the memory will be erased.
Aug 04, 2010 | HP 12c Calculator
PR ERROR
There is nothing to correct: the calculator is merely informing you that the continuous memory has been reinitialized. In other words all your data has been erased. Press any key to erase message.
You should expect this kind of errors once in while, especially if batteries have been depleted for a while or have been replaced.
Hope it helps.
Thank you for rating the solution.
Dec 07, 2009 | HP 12c Calculator
HP 15c Passes self test but screen flashes - wont turn off
You can get rid of the flashing (usually due to memory overflow) by pressing [<-- left arrow] [ON] or [g] [CF] 9.
If you want to reset permanent memory
1.Press and hold [ON] then press [-]
2. release the [ON] key, then the [-] key.
Screen displays Pr Error.
Press any key to clear display.
Hope it helps.
Sep 25, 2009 | HP 12c Calculator
NEED TO CHANGE THE VAT TO 15% ON MY CALC
press and hold % button until disply current rate. Then enter newrate and press % agian.
Apr 30, 2009 | Casio DF-120TE Calculator
C showing in display, how to fix
Begin - Press the blue "g" button then 8 ("end") to remove begin. Press the blue "g" and 7 ("BEG") to toggle back to having "Begin on display.
Feb 17, 2009 | HP 12c Calculator
How do I change the VAT amount on my Casio MS-120TV calculator
How do I program tax rate into my calculator? Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Nov 27, 2008 | Casio FR-2650Plus Calculator
HP 12C
gtabblt.gif Description gtabblt.gif Resetting the calculator using the keyboard gtabblt.gif Resetting to drain the capacitor gtabblt.gif Other solutions gtabseps.gif Description Sometimes a calculator will lock up or will not respond correctly. The calculator may require a reset for a variety of reasons. These resets will erase the memory on the calculator and restore the calculator’s defaults. For this reason, it is important to back up any critical data. Resetting the calculator using the keyboard The easiest reset is done from the keyboard. To reset the calculator, follow the procedures below in the order presented.
  4. Release [ - ] .
  5. The screen will display “ Pr Error
If the above reset did not restore the calculator to normal, continue to the next section.
Sep 04, 2008 | HP 12c Calculator
Cobra MT800
Hello SSPD12,
To turn off the tones whch sound whenever you press a key do the following:
1. Press the MODE button until the music note icon on the display flashes.
2. Press UP or DOWN to select the desired setting (either On or Off).
3. Press MODE again to save or simply wait 15 seconds.
Hope that helps.
Ken
"Go Ahead. Use Us."
Jun 03, 2008 | Cobra PR-245/2 (7 Channels) 2-Way Radio
HP 15C Scientific Calculator Logo
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
