Problem with charging my battery on my Toshiba Satellite
I plug it in but it does not start charging. If I wiggle the cord at the plug in area in the back of my laptop, sometimes it tries to start charging but the light immediatly goes out. I bought a new cord and charger but the same thing happens. Do I have to get a whole new motherboard and if so, I have one in an old Toshiba - Model M45-5169. Would they interchange?
  • 15,935 Answers
Your Power jack has either cracked the motherboard or the solder connection. This is what you are looking to replace....
Problem with charging my battery on my Toshiba Sat - b2711c3.gif And it located like this on the motherboard....
If you are good at soldering and de-soldering.... a repair can be made in-house.
The actual jack is about $15USD.
To have it repaired by a technician is approximately $150USD. Most of the $$ is for labor in disassembling the entire laptop to get at it.
Motherboards do not interchange, unless they are of the same model#.
Hope this helps.
PS - I have personally used the LAPTOP GUY for this exact repair because I didnt want the bother of taking the entire thing apart, and have extra pieces at the end. They charge an upfront diagnostic fee and that is taken off the repair - if you have them do it. Free postage in a box they supply too!
Posted on Jan 19, 2009
How can i fix my laptop not chaing
Wiggle the cord. Check to make sure the cord end is fully inserted into the power brick that is about half way up the cord.
Jun 09, 2014 | Toshiba Satellite L45t-a4230nr 14" Led...
The labtop doesnt boot when the charger is placed in and it also goes of when the charger is put in
Is the AC cord the original? Has it been damaged? Have you tried another AC cord, with the EXACT same power specs? It may be a damaged AC jack. Sometimes a pull or tug on the cord while plugged in will loosen the connection. If you wiggle the cord at the jack plug does it cause the charge LED to blink? Does the computer work on battery?
Nov 28, 2013 | Toshiba Satellite A305-S6863 Laptop
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
The power cord won't charge the battery. The
I can't actually solve this, but I have to wiggle my cord around to get it to "connect". I'm pretty sure my jack is loose, but haven't opened it up yet to check. This website looks like it has a promising solution on a similar laptop: http://www.laptoprepair101.com/laptop/2007/07/16/satellite-m35x-fixing-power-connector/
Jul 11, 2009 | Toshiba Satellite A215-S4747 Notebook
Toshiba satellite a130/a135 series. I connect to
check the power cord to the laptop in the back wiggle it. check the lights. if they come on and go off with you giggling the power cord. the ac input socket may be broken. you may have to wedge it in one spot to get the two lights to come on let it sit there a while 20 min to charge battery some then turn on laptop.
Jun 23, 2009 | Toshiba Satellite A135-S2276 Notebook
Will not power up for more than 1 second. Without battery installed, will not power up at all
Sounds like battery is dead. Have you been having problems with power cord? When you plug in power cord with battery installed you should see a charging light. Maybe wiggle coord and see if you get some power. Toshiba, In my opinion is a great computer, but they do have a poorly designed power plug. They are forever being broken from the boards. I hope this helps and if it is a bad power socket, you can get them from Ebay for about $5. Good luck and have good day.
Feb 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba P15 S479 Laptop
I had the same problem. The AC adapter connections on the mother board had to be resoldered.
Nov 04, 2008 | Toshiba Satellite P15-S479 Notebook
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
