Question about iRiver H340 MP3 Player
My iriver h340 when booting gets stuck n screen saying Loading...
I can charge it
i can reset it
the HOLD screen come up if I enable hold and then press button
I have let the battery drain overnight but still will not boot
it firsts starts with Start... - disk is whirring, then Loading .... then nothing just the blue screen stays
Is there a button sequnece to factory reset?
I have opened the case and removed the hard disk - but that did nothing either
SOURCE: Iriver H340 - battery
Visit http://xushi.co.uk/index.php?title=revive_your_iriver_h320_h340_with_a_new_&more=1&c=1&tb=1&pb=1 to see how its done. Buy battery from link to ebay
Posted on Apr 10, 2007
ambrose313
  • 85 Answers
SOURCE: iRiver H340 new battery won't hold a charge!!
It can be the charger that is actually causing your battery to not hold a charge. The closest thing to you would be www.iriverstore.com. connie
Posted on Jul 10, 2007
SOURCE: Iriver H340 motherboard?
Hi , the price of the motherboard you might as well buy a newe Iriver mate , but if you wanted you might be able to salvage one from a broken I river on an auction site since replacements are not readily avalible for the public .. and as for complexity ,
it shouldnt be too hard but technician to preform the repair job would save alot of hastle in the long run.
Posted on May 27, 2008
SOURCE: iRiver H340 firmware
with the hex file hold the navi button for a few seconds; you get four options select the general one then you will see an upgrade firmware option. select this the hex file on your player is your firmware it will then go through the upgrade process. don't touch while this is happening. it will turn off when done. then thats it. Be careful the version v1.30 will get rid of the video option go with v1.29 or less
Posted on Jun 24, 2008
SOURCE: iriver h340 - new battery charges but does not work when not in electicity
They may need to be on the other way.
Posted on Jul 30, 2008
Iriver h340 shows no content or does not load properly
Sounds like the battery is dead. Rechargeables only last so long. I'd copy all the content off it, before the battery dies totally, which could make it not work even connected to your computer. Looks like you can get a replacement battery: Iriver h340 Google Search
And here's a video on replacing the battery: How to Replace the iRiver H340 Battery
May 25, 2017 | iRiver H340 MP3 Player
Window XP does not recognize my H340 after battery change.
H340 should show as a removable disk drive. Ensure it is formatted as Fat32, run chkdsk, or scandisk. Does the H340 boot into play mode? you did not say. I replaced my battery with no problems... so if it boots Ok it is a non-related fault.
Dec 02, 2008 | iRiver H340 MP3 Player
Iriver H340 - new battery charges, but does not work...
Hi, I had the same problem with my H340. I bought a battery for $16 on eBay and swapped them out. The unit would say "Charging" but would never "Complete". When disconnected from the AC, it would not power up at all. I opened it up again and noticed that the old battery connections had the red wire on the left, the battery had the red wire on the right. I took the black and red wires out of the quick-connect jack and swapped them so that the red wire would no go into the player on the left. Works like a charm now.
Jun 28, 2008 | iRiver H340 MP3 Player
Screen Troubles
Sounds like the LCD controller has gone bad - must be replaced.
Try every "soft fix" first to be sure:
*Reset - button on side
*Firmware Upgrade (sounds like you tried it)
*Reformat the player -p.68 of manual - available on iRiver website if lost - enter model as H300 series
*Recovery -
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Jan 11, 2008 | iRiver H340 MP3 Player
Screen doesn't light up
I put 9 volts to my h340 and the screen lit up white and now I just faintly see the screen. I'm afraid I have to replace the screen. Know where I can find one. scottp@easystreet.net
Sep 15, 2007 | iRiver H340 MP3 Player
IRiver H340 new battery won't hold a charge!!
Jul 09, 2007 | iRiver H340 MP3 Player
IRiver keeps loading and loading and ...
Just a thought, try removing the battery, then holding the rest button in for about 15-30 seconds, release it, then re-attach the battery, if that don't work, try removing the battery, then re-attach the battery while holding in the reset button, then release the button after about 15 seconds. Konqueror?, That's a Linux based file manager/internet browser, is it on your PC or the iRiver? If it's on the iRiver, then the operating system is more likely Linux based, and removing the battery then re-attaching the battery while holding down the reset button, should!!! (not everything works as it should) reset the machine.
Jun 18, 2007 | iRiver H340 MP3 Player
Dropped the iriver. Headphone socket & power socket not working
This unit needs a technician to probably open it and assess the damage, most likely it just has dry joints and they need soldering.
Feb 25, 2007 | iRiver H340 MP3 Player
Cannot access files on h340
Sep 07, 2006 | iRiver H340 MP3 Player
iRiver H340 MP3 Player Logo
149 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
