Question about Acer Aspire 5100 Notebook
Restarted my computer and now it won't come back on! Help
Windows has problem communicating with a device connected to your computer...
This error can be caused by unplugging a removable storage device such as an external usb drive while the device is still in use, or by faulty hardware such as a hard drice or cd rom drove that is failing. Make sure any removable storage is properly connected and then restart your computer.\If you continue to receive this error message, contact the hardware manufacturer
Error message:
file: \windows\system32\winload.exe
status: 0xc00000e9
  • 2 more comments
  • s_dubay Jan 19, 2009
    cannot get it to go past the error screen to be able to do anything on the computer, you chose your operating system and it takes you right back to error message
    when I press F8 it brings me to boot with disk, will load files and shut down or bring me right back to error message
    My disk is now in the drive, and yes it gets to a certain point in loading files and stops and completely shuts down
    Genius:
  • Acer Master
  • 1,102 Answers
Right click my computer
then properties
hardware
then device
scroll down and see if you have anything with a ? or !
if you do click and update driver
if not let me know
Posted on Jan 19, 2009
  • DEKR
    DEKR Jan 19, 2009
    can you get in safemode by pressing F8 continuosly during a restart
  • DEKR
    DEKR Jan 19, 2009
    is your disk in the drive
    does ther whole system such as power shut off
Advent Q200 Quantum
Unplug, remove battery, leave battery out, plug in, reboot and try a System Restore to a date before this issue.
May 28, 2013 | Computers & Internet
Syncing my MobilePro 790 with my computer
yes...quite an issue, eh? what is the actual model and make of that device?
Mar 20, 2008 | NEC MobilePro 790 Pocket PC
250 error on documate 510 xerox
Symptom: When scanning you receive an error 250. Cause: This problem can be caused by several different things but is often a driver or communication problem. Solution: Here are several solutions that can resolve this problem:
Solution 1 - Check for communication problems
Using any of the following can cause communication errors:
  • USB hubs
  • Docking stations
  • USB extension cables
  • USB cables longer than 6'
  • Connecting the scanner to one of the computers front USB ports (desktop computer only)
Connect the scanner directly to a USB port on the back of the computer (or side for notebook computers) using a 6 foot or shorter cable.
If you still receive the same error message, try a different USB cable.
Solution 2 - Redetect the scanner with Hidden Devices
Windows Vista, XP and 2000 users
  1. Disconnect the power and USB cable from the scanner.
  2. Click here and select "Run" or "Open".
  3. The Windows Device Manager will open.
    • Click on the "View" menu then select "Show hidden devices".
  4. Click the "+" next to "Imaging Devices". This will show all Imaging Devices previously and currently connected to the computer.
  5. Right-click on the Visioneer or Xerox scanner name and left click on "Uninstall".
  6. If the scanner is listed more than one time, uninstall ALL occurrences of the scanner.
  7. IF you see "?Other Devices" in the device manager list, click on the "+" to view the list of Other Devices.
  8. Right click then left click on "Uninstall" for each occurrence of the scanner. The scanner may be listed as any of the following:
    • USB Scanner
    • USB Device
    • Unknown Device
    • 1200 DPI Scanner
    • (Your Scanner Model)
    • (any other scanners or cameras listed here that you no longer use)
  9. Click the "+" next to "Universal Serial Bus Controllers".
  10. Right-click every listing of "Unknown Device" and select uninstall.
  11. Once all instances have been removed from device manager, reconnect the power and USB.
Windows Me and 98 users
  1. Right-click on the "My Computer" icon on your Windows Desktop
  2. Select "Properties" from the list
  3. Click on the "Device Manager" tab
  4. Find "Imaging Devices" and click on the plus (+) next to it to expand the list
  5. Select your scanner, then click on the "Remove" button
  6. IF you see "?Other Devices", click on the plus (+) next to it to expand the list
  7. Select your scanner then click on the "Remove"; button – your scanner may be listed as any of the following:
    • USB Scanner
    • USB Device
    • Unknown Device
    • 1200dpi Scanner
    • (your scanner model)
  8. Close the Device Manager
  9. Unplug the scanner from the computer and from the power
  10. Plug the scanner back in to the computer and power
Solution 3 - Check for power problems
If the power for the scanner is plugged into a surge protector, battery backup (UPS), or extension cord, plug the scanner directly to the wall.
Solution 4 - Check for conflict with other devices
This error can also be caused by a conflict with another USB device.
  1. Disconnect all USB device from the computer (including the scanner), except for you keyboard and/or mouse
  2. Turn the scanner off
  3. Restart the computer
  4. Once the computer has fully restarted, reconnect and power on the scanner
  5. If the scanner works properly at this time, it means there is a conflict with another device on the computer
  6. It may help to isolate the two items by connecting one of them to a USB add-in card
Solution 5 - Test the scanner on a different computer
If possible, you should try the scanner on a different computer. If the scanner works correctly on a different computer, then the problem is environmental and may be related to your chipset. See solution 6 below.
Solution 6 - Check the computer's chipset
This problem can also be caused by the computer's chipset. To check the chipset:
  1. Vista, XP and 2000 users: Click here and select "Run" or "Open".
    ME and 98 users: Right click on 'My Computer', select 'Properties' then click the 'Device Manager' tab.
  2. The Windows Device Manager will open.
  3. Click on the plus (+) next to 'Universal Serial Bus Controllers'.
  4. This list will include your computer's chipset.
  5. The follow chipsets are known to have communication problems:
    • SiS 7001
    • VIA Rev. 5 or later
    • Open HCD
    • ALi
  6. If your chipset is one of those listed above or it is only listed as 'Standard', you can try updating the chipset drivers.
    • Contact your computer's manufacturer for more information.
  7. If the problem persists, you may need to use a USB add-in card.
    • This is a PCI card that will add more USB ports to your computer.
  8. For more information about USB chipset issues, see www.usbman.com.
Jul 12, 2010 | Xerox DOCUMATE 510 Flatbed Scanner
Exact same thing.
if it doesn't see the printer at all , and you know that driver its suitable ..and used it before...try to manually install it from the add new hardware wizard or from device manager by right clicking and choosing update driver ...It will start the installation wizard and if you previously load the driver(install it) ..let it find it automatic..but if all is OK and it shows communications errors..than is a matter of operating system and you better reinstall the windows...
Sep 02, 2009 | Lexmark Z735 InkJet Printer
Won't scan photo to computer.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | HP Photosmart C4280 Aio Printer
Won't scan or copy
Solution
These errors are usually caused by a failed scan, a bad installation, communication problems or software conflicts. Follow the steps below until the problem is corrected.
Step one: Restart the computer
Close all programs and restart the computer. A required task might have stopped running or the system resources might have decreased due to tasks left running. Restarting the computer will refresh all Windows tasks as well as increase the available system resources.
Step two: Check for the correct entries in the Device Manager
Verify that the unit was installed on a DOT4 virtual port in the Device Manager.
  1. Right-click My Computer , and then click Properties .
  2. Click the Device Manager tab. (In Windows 2000 and XP, click the Hardware tab , and then click Device Manager .)
Check the list of installed devices for references to DOT4. If there are no DOT4 references, the software has not installed correctly.
If any of these entries are missing, the software did not install properly. Review the information in the HP document Troubleshooting Installation Issues for USB-Connected HP All-in-One Products in Microsoft(R) Windows (bpu01858) for installation assistance.
Step three: Check for communication problems between the all-in-one and the computer
Communication might have failed between the all-in-one and the computer. Review the information in the HP document USB Connected HP All-in-One's Software Reports a Disconnected or an Error Status (bpu01859) to check for communications problems between the HP all-in-one and the computer.
Step four: Check the computer to see if it is infected with a computer virus
If the all-in-one prints but will not scan correctly and does not show any symptoms of communications problems, the computer might be infected with a virus. Some viruses try to disable virus scanning software and in doing so disable scanning from the all-in-one. The following are symptoms a virus problem:
  • The scanning software works after installing the all-in-one software until the first time the computer is restarted.
  • In the Device Manager, opening the Properties of the Imaging Device entry will reveal a status of "code 19" or "code 28".
  • A Scanner Cannot be initialized error occurs. While this error may other reasons, a virus will cause this error.
When the all-in-one is turned on and connected, follow the steps below to see if this is the problem:
  1. Right-click My Computer (click Start first in Windows XP) and then click Properties .
  2. Open the Device Manager:
    • Windows 98 and Me: Select the Device Manager tab.
    • Windows 2000 and XP: Select the Hardware tab, and then click Device Manager .
  3. Locate the Imaging Device entry and click the plus (+) beside it. It may have an exclamation mark beside it.
  4. Right-click the all-in-one entry under Imaging Devices, and then click Properties .
  5. A Properties screen will open. Look at the Device status section.
Hope it may helps;.
Regards, VOTIT
Sep 20, 2008 | HP Photosmart C4180 All-In-One InkJet...
Acer Aspire 5100 Notebook Logo
489 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
