Mitsubishi medallion HD1080 Apple TV clear sound scrambled video
I have a mitsubishi medallion HD1080 which does NOT have a HDMI input port. However, I connected my Apple TV ver 2 via a HDMI to 5 RCA converter on the DTV port on the mitsubishi, which theoretically should be able to take 1080i input. Currently I am getting clear sound but scrambled video. Any suggestions on how to fix this problem? Thanks.
  • Gautam Goel Jan 04, 2013
    **Typo correction: I have Apple TV ver 3
I have a mitsubishi HD1080 series TV and wanted to know how do I plug in a dvd player. Then how do I get it to play.
Connect an HDMI cable from the DVD's HDMI port to an unused HDMI port on the TV. Select the input from the settings menu and name it DVD or select the DVD name. Turn the DVD player ON. Using the input select button on the remote, select the HDMI DVD input. Wait a few seconds while the TV and DVD player establish a connection. The DVD player menu should appear. Insert a DVD and enjoy a movie. Hope this helps. Regards.
Jan 02, 2016 | Mitsubishi Televison & Video
I need to be able to connect DVD player to output 3 on Mitsubishi Medallion hdtv 1080 we can't seem to get it to work
It needs to be input if you want to display some on the TV from the DVD player. HDMI is the easiest as it's both audio and video.
Jun 01, 2015 | Mitsubishi LT55164 Unisen Medallion 55...
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Does this TV have a more than one HDMI in port.
My WS 55311 HD1080 series has hd obviously but i cant fiund any hdmi ports...
Dec 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Nov 17, 2009 | Televison & Video
Manual mitsubishi medallion hd1080
MY MEDALLION WILL NOT TURN ON THE GREEN LITE IS GOING ON AND OFF THAT SAYS TIMER ON CAN U TELL ME THE PROBLEM.
Mar 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
