Question about Singer 7442 Mechanical Sewing Machine
How do I replace bobbin case singer 6831 need diagram
    Sergeant:
  • 475 Answers
Look on line bring up the make and model and they might have that there when you look up the singer, or call the manufactor.
Posted on Jan 04, 2013
Diagram of bobbin casing for singer 1036 creative touch?
Try a brand new needle and verify it is installed correctly. Rethread the machine, top & bottom.
If the machine continues to miss the bobbin thread, most likely the timing is off. Search for sewing machine timing or take it for service.
Singer 1036 parts diagram Google Search
May 25, 2017 | Singer Sewing Machines
I need to see a diagram for a Singer 368 bobbin case
When you get to this web site just type in Singer 368 bobbin case and the picture will pop up.
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
Apr 29, 2015 | Singer Sewing Machines
Singer 9420 bobbin case diagram
http://www.singerco.com/uploads/download/452_5_8_10_16_22_dial.pdf is the manual for the machine. The bobbin case is a single piece, and looks like: http://www.sewingpartsonline.com/bobbin-case-body-singer-383913-901.aspx?gclid=COqlw9-9yL4CFQqPfgodiC8A6g I don't know of a diagram of it.
Dec 22, 2013 | Necchi Sewing Machines
Could you check to see if that is the correct model number? I cannot find anything on a Singer 9420.
Dec 22, 2013 | Singer Sewing Machines
Singer 7430 bobbin case clicking sound
it's possible that the bobbin case did not get inserted correctly
or it's also possible that the bobbin case needs to be replaced, I've had to replace the bobbin case on one machine.
May 30, 2012 | Singer 7430 Sewing Machine
My singer futura ce100 bobbin case (the metal part that actually holds the bobbin) keeps popping out. I do not know how to put it back in correctly in the seat. There is no diagram anywhere for that. It...
It may be that the silver square object in front of it is to tight. I had this happen and I loosened that up with small screwdriver and put bobbin case back in and it helped. Had to play with it for a while. Or It may be that the bobbin case has chip out and need to replace that.
Aug 12, 2011 | Singer CE-100 Futura Computerized Sewing...
Singer 20U73: I have removed the bobbin case holder (2 screws) due to a suspected problem I have tried many times to reattach it, but cannot seem to find the correct position on the spindle. It will not...
  • To replace the bobbin case please follow these steps and reference the diagram I put up.
  1. Grab the bobbin case by the latch (#1)
  2. Now place it on the spindle of the bobbin case holder (#2)
  3. You want the notch (#3) and (#4) to match up at 3 )'Clock.
  4. Now close the bed slide.
Regards, Tony
May 29, 2011 | Singer 20U73
I have a Singer model 4562 T sewing machine, and threading the bobbin, the bobbin case just kind of popped out. I've tried just sliding it back in, but no matter which way I put it in it doesn't seem to...
The bobbin case is designed to be removed for cleaning. Take off the needle plate if it is still on the sewing machine. Make sure that the needle and presser foot are fully up. Guide the forked end of the bobbin case under the feed (more or less centered). Then pull the bobbin case under the rim of the position plate. Pull on the side opposite the forked end of the bobbin case. With a small screw driver, turn the lever (at about 10 o'clock on a 12-hour analog clock) towards you. This will lock the bobbin case into place. Make sure that the bobbin case isn't locked too tightly. It still needs to move slightly as the bobbin turns and the needle comes through that plate.
Replace the needle plate and lock it down. Then insert the bobbin and close the slide plate. The manual shows the procedure to remove and replace the bobbin case on the 4562 on page 39. Singer has the manual on the support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/435_5_8_10_16_22_dial.pdf .
I hope this helps.
(I hope that the locking lever hasn't broken. That may require a service person to solve the problem. I'm not entirely sure where that lever is connected to the machine. Some Singer part diagrams are here: http://www.singerco.com/support/replacement-parts-chart . The 4562 may use the same diagram as the 4572, http://parts.singerco.com/CPpartCharts/4_4999/4572.pdf .)
Jul 01, 2017 | Singer Sewing Machines
How do I replace the bobbin case in singer machine 7442. The manual diagram is minimal and I replace it incorrectly and just got it out after several attempts. Can't seem to get it aligned proper;u
When you insert the bobbin case, make sure the "knub" on the bobbin case (#1) is just to the left of the position finger bracket (#2). It should sit in there nicely and you should be able to spin the hand wheel freely.
Let me know if you need more help,
Chris
Jun 07, 2010 | Singer 7442 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
47 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
