Question about Car Audio & Video
Wires for DC power connection
Wires: Red, Black, Blue, White/Blue, Green, White/Green, Brown, White/Brown. What wires is +/- for DC power connection?
  • Imya Jan 04, 2013
    CCTV camera Pelco ICS300-CRV3A
  • 691 Answers
Black is usually negative; red is usually positive the coloured wires with a corresponding wire with a stripe are usually speaker wires where the white striped wire is negative. please state the exact model you want a wiring diagram for to see if we can help more
Posted on Jan 04, 2013
Testimonial: "Many thanks for your help!"
  • 4 more comments
  • Imya Jan 04, 2013
    Hello Daniel! Thank you for your reply. This is CCTV camera Pelco ICS300-CRV3A. That camera supports 24VAC or 12VDC. In manual of camera I see that I should use 12DC power connector. But I have not this connector, because I got the cameras from Ebay. And in whole internet I can't found a wire diagram for this model of Pelco cameras. Very strange that this information is not listed in manual.
  • Daniel Bakewell Jan 04, 2013
    Thanks for clarifying, i was on the wrong track altogether. You need to be very careful not to connect this unless you are using the specified power source. The camera data sheet states 12vdc or 24vac but it doesnt mean it will use either power source. It means they manufacture two cameras almost identical, you choose 12vdc or 24vac when ordering.
    sorry, this is embarrassing, i have too many internet pages open and i read the wrong one, it is a dual voltage camera, and I appreciate you need the wiring harness for the 12v application. next post should have some useful information please stand by!
    OK... for 12vdc Red is (+) black is (-). if you use 24vac it wont really matter which way round they are put. The camera should auto sense the power supply you give it and work automatically. The other wires are for video signal. this link might prove useful, and if all else fails contact pelco: http://www.pelco.com/sites/global/en/pro...
  • Imya Jan 05, 2013
    Hi Daniel! Thanks for useful information! Today I will try
  • Imya Jan 05, 2013
    Hi Daniel! The solution has been found! Yes, for ICS310 series the red/black is true. But.. For ICS300 series the BLACK is - and WHITE/BROWN is +. Thank you anyway for your help! Even integrated heater in camera starts good, the proof in attachment:) PS: in Siberia now -40C :)
simplemitch
  • 752 Answers
SOURCE: Wiring Problems
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10. If you DID..... well..... we have a LOT of work to do....
Posted on Sep 11, 2007
KaeZoo
  • 156 Answers
SOURCE: wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Posted on Jun 06, 2007
simplemitch
  • 752 Answers
SOURCE: CDC-R304
red = 12 volts switched (ignition)
yellow = 12 volts constant
black = ground
blue = power antenna
blue/ white = amp turn on
purples = right rear
grays = right front
greens = left rear
whites = right front
black striped speaker wires are negative side
Posted on Nov 09, 2007
SOURCE: need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
Posted on Jul 29, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
Need wire color diagram
Black = AC hot
Red = switched AC hot
Yellow = AC hot from a another source - another control panel as an example.
White = neutral
red w/white tracer = switched neutral
Green or green w/ yellow tracer = ground/earth ground
blue = DC voltage, ie, 12vdc, 24vdc
white w/blue tracer = dc common
Brown = AC 3 pahse - phase A
Orange = AC 3 pahse - phase B
Yellow = AC 3 Phase - phase C
shileds: think of current loops
2 cond
clear or red = +
black = -(neg)
3 cond
red = power (24vdc typically for transducers)
clear = + (signal output)
black = - (signal common)
Hope this helps, oh, and any panel I have design and wired this way is easily understaood by 99% of all service and electrical people I have worked with.
Apr 15, 2015 | Cars & Trucks
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
Radio was removed from my 91 Seville and replaced with aftermarket CD player radio. I would like to use this radio in my shop. I have 12 DC supply and speakers and antenna. Note: There is no place to plug...
This should be the wire combination for your car: nstant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Speakers
Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Speakers continued
Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Apr 13, 2011 | Car Audio & Video
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I have a cat5e wall plate(tph552) a cat5e wire4 colors don't match and 4 colors do ( brown,orange,blue,green,) are ok then wire has 4 that are white with (brown,orange,green,blue,)stripe. and wall plate...
The wires/colors in a category 5e cable run in pairs. They should be tightly twisted together, mostly white with a blue tracer. mostly blue with a white tracer- mostly white with an orange tracer- mostly orange with a white tracer, mostly white with a green tracer- mostly green with a whte tracer, and mostly white with a brown tracer- mostly brown with a white tracer.The jack you have sounds like a standard telephone or cat. 3 jack. If the jack is being used for a standard telephone line, you'll need to connect one of the wire pairs(usually the white/blue pair) to the green and red terminals on the jack.Make sure that the same pair is also terminated at the main telephone junction.
Aug 08, 2010 | RCA Computers & Internet
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
The sensor has 1 red, 1 black, 2 white wires?
BROWN = PHASE BLUE = NEUTRAL.
European code.
BROWN = BLACK WHITE = BLUE
Feb 06, 2010 | Garden
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Car Audio & Video Logo
103 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
