Adjust mirror on my telex caramate 4000
My mirror was knocked out of kilter by move. I need to find someone to adjust the mirror. I'm in New York City.
2 Suggested Answers
  • 24 Answers
SOURCE: can't get light to project - do slides need to be in the carousel?
Try this website..
http://www.photobooksonline.com/books/manual43.html
Posted on May 11, 2009
I just got a used Telex Caramate 4000 slide projector but no manual. Who has one I can buy?
sadly when buying used items getting a manual would be the first thing I would ask about from the seller .. you can try searching thru Google and hope for the best
Jun 07, 2016 | Office Equipment & Supplies
Want to transfer slide pictures from a Telex Caramate 4000 to a laptop. Is it possible to do this?
you need telecine transfer facility take it to duplication house they might help ypu
Dec 21, 2013 | Telex Caramate 4000 Used Audio Visual
Projector turns itself off and on
Caramates have a Thermal Breaker built into their electrical circuits, which will "open" if the internal temperature gets too high for safety. When the internal temperature drops to an acceptable level, the breaker "re-sets" and the projector will come back on. You will need to check for any obstructions to air flow first. Next, make sure the exhaust fan is running at the proper speed. Once those items are checked, if the problem still exists, you will need to locate a circuit diagram and the appropriate thermal breaker for replacement. Good Luck!! Jim
Oct 27, 2013 | Kodak Office Equipment & Supplies
My right mirror on 325 i 2005 doesn't work. When i change my seat position with the memory, the seats goes on but not the mirrors. I can adjust my left mirror but not the rigth one; it never move.
I would safely assume your right mirror may be inoperable period then by your statement you are leaving the switch for the mirrors in the middle during switching correct and during adjustment are switching to R/L mirror on the switch? Mirrors are on the same circuit so both should be operable. Have the mirror checked for operation before heading any further. I Think you will find during this its unplugged from its source of power or inoperable period and needs replaced. Remember to rate my solution and leave testimonial PS please purchase you a Owners Manual for your car you will thank me later.
Oct 09, 2012 | 2005 BMW 325i Automatic
Everytime I try to copy a tape, there's a big noise on the duplicate ones, even if the recording level is zero! I cleaned the heads with alcohol, but the problem remains. I have a TELEX ACC-4000. Many...
Is this a big bass hum?
Are you in the USA?
These are all mostly pretty old units by now but pro equipment none the less.
It's got circuitry problems but may be worth repair as I'm not sure anything like this is made anymore.
Sep 21, 2011 | Telex Copyette 1-2-3 Single Dual Cassette...
I have an OLD telex projector. Looks like a box with a tv screen on one side and carousel on top. have no idea how to use it. maybe bulb needs replacing
Telex called those "CaraMate XXXX" (XXXX usually relating to model number ). The old ones projected on the internal screen. Newer models could project both on the internal screen and (by sliding a door on the top panel) on a projection screen for larger audiences.
If it needs a lamp, check with: www.bulbman.com But you may have to search - - it's been a long time since they were manufactured!
Good Luck !!
Jun 21, 2011 | Telex Office Equipment & Supplies
Knocked burner off kilter & it won't reset into place or turn on
you should take it off anf take it to lowes, home depo, or a appliance store and replaceit it should be fine then. It most likely got cracked.....
Jul 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
Slide/tray advancement
http://www.fixya.com/support/t1564949-slides_advance_continusly
This link talks specifically about a Kodak slide projector. However the faulty mechanism in your Telex works in a similar way if you feel up to taking it apart. If you do, mark every screw and piece you remove, in a diagram. Though your symptom is sporadic advancing and the other link is continuous advancing, it's essentially the same cause, as sticking trigger mechanism in the clutch release.
Jan 27, 2009 | Telex 3280 Caramate 80 Slides Rotary...
75 people viewed this question
k24674
jasbo
jasbo
