Question about Vtech VT 1901 Cordless Phone
How to unlock my vt 1091BK phone?
My phone shows the locked indicator and all the keys are locked. how do i unlock it?
Doors lock remote driver
you could need new batteries in the remote.
Dec 17, 2013 | 1998 Holden VT Commodore
Phone is showing emergency calls only
Hi, you can unlock "Network lock control key" screen with the following service for your phone model: http://www.fastgsm.com/en/samsung/samsung/gt-i5503/unlock-code
Nov 16, 2012 | Samsung GT 15503 Cellular Phone
How do i un freeze my nokia twist
  1. Make sure that the keys are actually locked. If you attempt to unlock a keypad that is not locked, nothing will happen. Look on the phone's screen for the key icon that indicates the keypad is locked. If you try to press any of the keys and the word "Unlock" appears on the screen, your keypad is definitely locked. If you do not see the indicator but are unable to use the keypad of your Nokia 6085, your battery could be dead, so try recharging it and then see if the keypad works.
  2. Enter the unlock sequence. If the key indicator appears on your screen, you need to enter a simple sequence of keys to get the keypad working again. For the Nokia 6085, select Unlock and then quickly press the * key. If you wait more than 1.5 seconds to press the * key after selecting Unlock, it will not unfreeze the keys so make sure you enter the sequence very quickly.
  3. Turn off the automatic keyguard. If you are tired of having to unfreeze the keys every time you want to make a call, you can program the Nokia 6085 to always remain unlocked. In the menu, go to Settings, then select Phone, then select Automatic Keyguard and choose Off.
Mar 01, 2012 | Nokia Cell Phones
How to unlock keypad nokia 3110c.
It sounds like your keypad lock (keyguard) is on.
To unlock the keypad, press Unlock and then press the asterisk key (*) within 1 and a half seconds.
The word Unlock appears above either the "Left Selection Key", the "Middle Selection Key" (4-way scroll key), or the " Right Selection Key" just below the display, indicating which key is currently the "Unlock Key".
May 23, 2011 | Nokia 3110 Cellular Phone
What is the default password for micromax x2i mobile
The Keypad Lock Icon is seen on top of the screen at various positions depending on the number of icons displayed. An Open Lock signifies that the phone’s keypad is unlocked and a closed lock signifies that the keypad is locked. You can unlock the keypad by pressing Unlock (by right soft key) on the phone, followed by the Send (GREEN) key. Similarly for locking the keypad, press the End (RED) key, to be followed by the Send key.
The user guide for your phone does not indicate a default pass code. Most default passcodes are either 5 or 6 zeros. Some are 12345.
See user guide:
http://www.micromaxinfo.com/downloads/guide/X2i_UM.pdf
Jan 26, 2010 | Cell Phones
Side key to lock is damaged of motorocker E6 phone
Dude just remove your side key away from your phone u vl find a small up & down key in side slot of side key take your stick & put it down to unlock use ur stick to lock or unlock ur phone..
Sep 24, 2009 | Motorola Mobility MOTOROKR E6
Philips cordless phone message indicates "keys locked"...can't dial.
You should have a key symbol on the * key. Press and hold this to turn on and off the lock feature.
here is your phone manual
Oct 24, 2008 | Philips DECT 2252S Cordless Phone
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Vtech VT 1901 Cordless Phone Logo
51 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
