Garrison convection heater model 052-2025-6 thermostats is locked
I have replaced the thermostats battery and have lights but the battery indicator is still flashing and the heater won't turn on
  • 1015 Answers
SOURCE: Hi, Vulcan " burwood " gas space heater.I have
As long as the burner works it is unlikly that the thermostat is your problem. It is more likly the fan limit switch needs replaced.Unfortunatly I am having no luck finding a wiring diagram for this model so I can't tell you where it is at,but I think that's the problem. Thank you. Sorry I'm not more help
Posted on May 19, 2011
Testimonial: "Hi frodo,Thanks for the quick response i will try the advice you mentioned. I will let you know if this works.Thanks again. olmate 56"
SOURCE: Replaced the thermostat on a fireplace heater from
Maybe need a Millivolt thermostat ?
Posted on Nov 10, 2011
  • 288 Answers
SOURCE: Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Posted on Jan 09, 2010
KevinWhite
  • 1902 Answers
SOURCE: Simpson Silencio 980. On 'normal'
Hello & Welcome to FixYa
If you have already tried to clean the drain pump-filter assembly located inside the bottom panel then the problem is with the timer that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Apr 30, 2011
eagle338
  • 4889 Answers
SOURCE: lg model 42pm4m plasma monitor won't turn on, red
Does the tv make a clicking noise like its trying to turn on before the tv goes into standby and the LED starts flashing? I suspect this is due to a shorted component, most likely to be in the 5V(switching) line and just want to be a bit certain before we start testing the power supply.
Posted on Jul 31, 2011
Tell me how to program a garrison 2000 watt convection heater model 052-2026-4
Better yet, Google (garrison)(052-2026-4)(manual) without parens to get instructions.
Jan 17, 2017 | Heating & Cooling
Manual for garrison oil heater model #043-5863-4
You should be able to download a manual here:
garrison oil filled heater model 043 5863 4
Also please be advised, your model may be under recall due to fire hazard:
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2013/36781r-eng.php
Nov 16, 2016 | Heating & Cooling
My garrison water heater is under warranty and I can't the replacement.
The warranty would be through garrison or covered by an insurance policy. Get the paperwork, should be on the side of the water heater in a pocket. Read through to find out who the warranty is through. If that doesn't help go to small claims... gets them moving Everytime
Jan 02, 2015 | Hardware & Accessories
How do I change the lithium battery in my Garrison Programmable Thermostat Model No. 52-8896-6?
The front faceplate simply pulls off - no tools required. The Garrison uses 3 AA batteries. Once you pull off the faceplate you will see where the batteries go.
Hope this helps!!
Nov 01, 2014 | Heating & Cooling
Why doesn't heater heat up when turned on ?
  • I bought 3 convection heater ( model 052-2026 ) .Two of them stop to heat after 2 years using . The third, stop to heat last december. Canadian Tire ( store where I bougt the product ) told me to contact Garrison Company . Now , I want to get refund. Michel L?ger Quebec, Canada
Mar 04, 2014 | QMark Portable Hydronic Electric Baseboard...
This heater is a 2000 watt garrison convection wall mounted heater. the light is on but the heater does'nt heat up
The heater is disconnected or there is a damaged wire. You can try to open it up or bring it in. I would suggest bringing it in for repairs.
Elisa Jed ' http://www.encoremec.com/about
I need to program my garrison convection heater 1500W
i want the spects for the 1500w garrison plug-in convecton heathger
Nov 05, 2013 | Heating & Cooling
How to set thermostat for garrison 052-2025-6
Hi my name is Dan I miss place my manual for my Garrison Convection Heather 052-2025-6 trying to set thermostat having trouble. My e-mail Danthehandyman@homail.ca
Nov 20, 2012 | Heating & Cooling
Garrison heater red light on but no heat
I just fixed mine with the same problem. I first called Garrison and they wanted to send a tech out to fix my $60 heater that was just of warranty..I said no of course. Any how I have a electronic background so troubleshot myself and found a thermo fuse that was bad. It was located inside the heater and not easy to get to but that was the problem. I am guessing that the fuse goes because of blockage at the top of the heater. Any how it's fixed.
Oct 24, 2012 | Heating & Cooling
Heating & Cooling Logo
800 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
