Question about HP LaserJet P3005n Printer
Wrinkled paper hp laserjet p2055dn
This printer prints pages with dogeared corners.
    Scholar:
  • 66 Answers
Make sure paper is seated in cassette under the tabs. If that is ok then you will need a new fuser assy.
Posted on Jan 04, 2013
2 Suggested Answers
  • 10 Answers
SOURCE: HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Posted on Jan 29, 2010
My hp P2055dn on prints blank pages
Hate to ask this question. But did you just install a new toner without removing the plastic strip?
Sep 22, 2016 | HP P2055DN LaserJet Monochrome Printer
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Aug 01, 2012 | HP LaserJet P2055d Printer
Hp 1300 Prints fine but creates a slight wrinkle afterwards on the top left corner of each page. I have blasted the insides of the printer with compressed air whihc made a slight difference.
This could be due to either dust inside the roller shutter or due to paper block which is torn and stuck. I suggest you to get the printer serviced by a near bye service centre.
Good luck.
Oct 19, 2010 | HP LaserJet 1300 Printer
2 reasons:
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
Paper printing with wrinkles on hp 4100 laser
Pressure roller is worn. But the whole fuser assembly could probably stand to be replaced.
Mar 28, 2009 | HP LaserJet 4100n Printer
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
HP 1300 makes noise and wrinkles paper
open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Dec 18, 2008 | HP LaserJet 1300 Printer
Paper Wrinkle when Printing
Its time you need to change the Tension roller of the printer.
Dec 16, 2008 | Office Equipment & Supplies
HP LaserJet P3005n Printer Logo
209 people viewed this question
Seeker5211
Seeker5211
