Lg FLATRON M197 wdp with v3.04.0 on screen...remotes dont work...buttons on side dont work....the message goes from left to right then back again ....screen is white....????
Small box with V3.04.0 on screen moving across from left to right then back again..remote does nothing ....buttons on side have no effect ....any ideas.....is it in some sort of service mode????
likha
  • 790 Answers
SOURCE: pip
ok nimrod they have many types of settings about pip viewer,will you please give the brand and model?
Posted on Sep 24, 2007
  • 1694 Answers
SOURCE: pip only on screen
Try hard reset first==Unplug ac cord overnight, then try again.Possible signal board trouble-- Practice visual acuity technique==look for CRT coolant leak on circuit board. Also suspect PIP PCB==can be by-passed by a knowledgible tech.
Posted on Sep 26, 2007
SOURCE: digital power saving mode
check your monitor power settings.
right click on your desk top then left click on 'properties' in the white box that appears.
this will bring up a 'display properties' box which should have a tab headed 'screen saver' amongst others.
select the screen saver tab.
in this tab there are 2 sections. one to select which screen saver you want to use (and what settings are applied to it), and another section which should be called 'monitor power'.
click the button here which says 'power...' to adjust your power settings.
in the next window there are 4 tabs. select the first tab (power schemes - which should be already selected by default) and you now have 4 options. leave the selected 'power scheme' in the top of the window as it is and just alter the settings for the selected power scheme.
your 4 options are: 'turn off monitor', 'turn off hard disks', 'system standby' and 'system hibernates'  i would recommend setting all of these to 'never', and don't forget to click the 'apply' button after you've done this.
i would also recommend disableing hibernation in the 'hibernate' tab (this is in the same window as the power schemes tab).
once you've adjusted your power settings, don't forget to activate one of your screen savers.  this is only important if you leave the monitor on for a long time with no changes taking place in terms of what is being displayed. if you leave a static image on for hours you will end up with permanent screen burn. (a ghost image that is always there - even when the monitor isn't switched on!).
i don't bother with screen savers personally as i find them annoying, and find it much easier to simply turn the monitor off whenever i'm not going to be using it for the next hour or more.
hope that solved your problem. apologies if it doesn't.
by the way, the tabs etc i described are what i have on my OS (windows XP pro) and may be named differently if you're using a different version of windows.  the 'power options' settings will still be accessible via 'screen saver' tab in desktop properties though.
good luck!
:o)
Posted on Oct 19, 2007
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
Posted on Sep 14, 2008
  • 414 Answers
SOURCE: screen dead
since it's only 3weeks old as long as you have the receipt take it back .
Mark
Posted on Apr 18, 2009
Hello i have a 19 inch LG M197 WDP monitor/tv, when i switch it on the screen is white with a little gray bock that flashes and slowly moves across the top of the screen reading v3.02.0 which i presume is...
I also had an LG M197WDP tv/Monitor with the same problem. It comes straight on when plugged in, but with the blank screen and scrolling version number across the top.
The solution:
1. Use the remote control (check batteries first)
2. Point at the working TV and press either MENU or EXIT
3. Static should be seen on the screen.
4. Switch to standby using the remote, by preesing POWER button.
5. Switch back on using the POWER button.
All should then be working normally
Jun 20, 2011 | LG M197WD-PZ 18 inch LCD Monitor
Lg flatron m227 wdp tv is it a multisystem
No...it´s only a Pc Monitor or TV...don´t come with DVD or VHS if it´s what you mean...
Feb 27, 2010 | LG M227WD-PZ LCD TV
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
LG Flatron w1952TQ screen half darker on right side
Try clicking the auto adjust button on the screen. If this doesn't work it may be in demo mode, so click the fENGINEbutton on the monitor and make sure it is selected on the normal setting.
Aug 04, 2009 | LG Flatron L1919S LCD Monitor
Screen display
You have control buttons for the OSD either on the bottom or the side of your monitor.
Push and enter the set up and push buttons until you see the arrows that move the screen up or down, right or left.
Your model may have one of the buttons marked automatic. If so, pressing that one will center the display on your monitor.
Let us know if you still have a problem!
Sirwriter
May 13, 2009 | ASUS Computers & Internet
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
LG Flatron problem
i get a black screen and an orange light in my lg lcd flatron whenever i turn it on.. i cnt use my pc because of this problem.. i hope u would answer my question...
u can email me at jmaonir@yahoo.com
tnx man :)
Apr 09, 2008 | LG Flatron L1710S 17" LCD Monitor
Computers & Internet Logo
370 people viewed this question
David Payne
David Payne
