Question about Toshiba MK 4018GAP (MK4018GAP) 40 GB Hard Drive
External Hard drive doesn't want to work
I have a 40 (or 80) GB, USB, external, Toshiba hard drive that use for file back-up and to move files back and forth between work and home. The HHD model is MK4018GAP. I'm using Windows XP Media Edition on a Toshiba Satallite laptop that has always run perfectly. It's about 3 years old. The external drive may be 4-5 years old.
Last week it began cycling on very slowly. I was still getting the auto-prompt that you get when it cycles on, asking if I want to open the drive with such and such program.
This weekend the drive began screwing up. I no longer get the auto-prompt to open the drive, and I believe it's causing my laptop to hang-up. The light cycles from red (when you plug it in) to green, just as if would if were operating correctly. However, the drive doesn't show in "My Computer" as it always has.
Looking in the Device Manager, it shows as a "Mass Storage Drive" where it's always shown as a Toshiba MK4018GAP. In looking through the properties of the device, sometimes it's listed correctly, sometimes it's listed as a Mass Storage Device but I have no access to the files on the drive. As well, within the device manager on the device properties tab, sometimes it tells me the device is working properly and has a driver, other times it tells me there are no drivers installed.
I've done about everything I know how to do except swap out the USB cable. I was told, which is obviously wrong, that "they" don't make USB to USB connectors such as that which is on my external drive. I have two standards sized connectors, one on either end of the cable. Not sure of the defintion of "A" and "B" connectors, I assume the "B" is the little small USB connectiion with the hexagonal-shaped plug. I have two large USB connections on my drive, with no cages around the tongue of the USB connection. Nothing at Best Buy, nothing at Radio Shack. All they carry are the USB with the large connection at one end, and the smaller connection at the other end.
Also - when the drive is plugged in, sometimes it seems to be interfering with my celluar modem. At times, I cannot get my cell modem opening screen to come up. When I remove the USB HDD, the cell modem screen comes right up. The cell modem is also a USB device. I have no other USB devices plugged in, I have no yellow question marks or problems indicated in the device manager.
So - I'm at a loss, and I have 20-GB of law enforcement cases, 5 years of college work and pictures from my travels around the world that I cannot get off this HDD. I bought a new HDD today but I NEED the only to come up JUST ONCE so I can get my stuff off that drive.
Any ideas you may have will be most appreciated.
  • uscg_counter Jan 19, 2009
    I haven't tried that (system restore) only because I recently installed new software while trying to research the "no driver" issue, as well as removing software I no longer use. I thought perhaps somehow something I removed may have been intermingled with the external HDD but, that didn't make any sense.
    If I do a System Restore, am I going to lose any software I recently installed, or gain software I recently deleted?
    I'll give it a shot. I'm not a computer GURU but I know just enough to be dangerous.
    I'll try it and post if it helped.
    THANKS.
  • 903 Answers
Have you tried a system restore incase some system files have become corrupted other the past couple of weeks.
If not try it first, Click on Start>all programs>accessories>system Tools>system restore and restore your system to a date and time when you know that your drive was being read with no problems. Once you choose the date and time, the computer will restore and reboot. The restore program will then reopen to tell you if the restore was succesful or not.
Once the screen has been displayed click okay and then plug your hard drive back in.
Hopefully this will help if not let me know by posting a comment.
Posted on Jan 19, 2009
  • 1 more comment
  • Debs
    Debs Jan 19, 2009
    yes, although the software that you removed may not work but still show as installed and the latest software that you installed will not be there but may still leave behind some files. If you still have the software that you loaded and you installed it before you got problems with the hard drive it may be the cause of the problem, as is uninstalling software that may have drivers that the hard drive relys on. It is up to you. Personally I would try the restore (it may or may not work), if you want to access your files.
  • Debs
    Debs Jan 19, 2009
    okay let me know how you get on
  • Debs
    Debs Jan 21, 2009
    How did you get on?
Can i attach an external usb hard drive to a toshiba lcd tv
The usb external hard drive was designed to work with windows operational system giving access to all the files, attaching the hardware would give limited use at best and may not respond.
Apr 22, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Rename toshiba external hard drive
Check to see if there is a file in the root directory called "autorun.inf". If there is, either delete it, or move it to a backup folder. Now you should be able to rename your portable hard drive.
If you don't see the new name take effect right away, Safely remove the drive, unplug it and plug it back in. The changes should show up immediately.
Mar 19, 2012 | Toshiba Canvio 500 GB USB 3.0 Portable...
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Toshiba external hard drive 640Gb appears on my laptop the USB connects perfectly ,it opens but doesn't take in any file .
hello, i would advice you to format your external hard drive by write clicking on it and click on format and click on start to begin, if this does not allow you to still put files on your external hard drive,then insert it on a friend laptop and see whether you can move files to it. I hope this helps. Regards
Feb 08, 2011 | Toshiba 640GB USB 20 Portable External...
My Toshiba external hard disk does not accepting backup from mac G5
my external HDD is not letting me drag and drop files from my mac. Is this my mac being secure? If so how can i remove it so i can store audio files on this device. thanks
Jan 23, 2011 | Toshiba 120GB USB 2.0 Portable External...
Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Mar 11, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Transferring Files to External Hard drive
I would suggest you find a backup program to do all this for you. I use EZBackItUp (http://www.rdcomp.net/ezbackitup/) a nice freeware program that is easy to set up. Once the files are backed up, though, you should not delete them from your C: drive, as the program will them delete them from the backup too. What you should try to do is move big files (movies, music, etc) to the external drive, which will give you more space on your C: drive. And, as always, make sure you run a good cleaning program (http://www.ccleaner.com for a great one, download and install) to reclaim some disk space.
Good Luck, and I applaud you for having a backup!
Dec 21, 2008 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Toshiba MK 4018GAP (MK4018GAP) 40 GB Hard Drive Logo
317 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
