Question about Craftsman 22" Gas Hedge Trimmer
Gas hedgetrimmer blade allignment. Need to align the blades correctly so they will cut I need instructions for blade realignment and assembly
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,308 Answers
ANY SEARS EQUIPEMENT CAN BE LOOKED UP ON SEARS PAERTS.COM
Posted on Sep 11, 2017
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
  • 109 Answers
SOURCE: I have a craftman 42 in dual blade riding mower.
Either the deck is uneven or one of the blades are upside down
Posted on Apr 24, 2009
  • 376 Answers
SOURCE: What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
Posted on May 17, 2009
  • 6 Answers
SOURCE: craftsman LT1000, model 917.272059 - cutting deck misaligned
If you wnt to level the deck you will need a tape measure and a 9/16 wrench and a LEVEL surface. Under the mower on the two lift arms/bars there is a nut on each side. you need to adjust these nuts up or down to raise or lower that particular side. When you make an adjustment to one side though keep in mind it will have the opposite effect on the other side. Hope this helps.
biomedguy9160@yahoo.com
Posted on May 22, 2009
SOURCE: Craftsman 18.5 riding mower when I engage the
craftsman decks have a positive stop adjustment for the decks. A spring atached to the blade ingadgement arm pulls the tension pully into position if the cable is rusted inside the sleeve it wont put enough pull on the ingadgment pully and thus the blades dont spin full force the belts on the mowers have no adjustments only the pully . second thing is you may want to drop the deck and clean around that pully by scraping any rust off the surface under the pullys slide good luck
Posted on Jun 20, 2009
Need operators manual to remove brushcutter blade
Hi mine has a hole behind the blade that you put a screwdriver in then turn the blade till it goes in to an aligning hole then it's screws off
Sep 27, 2017 | Craftsman Garden
I believe my table saw blade is not accurately aligned with the table and I can't find my Owner's Manual.
OK, first you should understand that the blade needs to be aligned with the miter slot. The easiest way to check this is to use a ruler.
UNPLUG YOUR SAW BEFORE BEGINNING!
First, use a pencil or a marker to mark the outside of one of the teeth on your blade, on the same side of the blade as the miter slot you're going to measure from. Position the marked tooth at the front of the table, then measure from the side of the marked tooth to the leading edge of the miter slot. To determine if it is aligned correctly, you simply spin the blade around where the marked tooth is at the back of the table and measure it again to the leading edge of the miter slot. The measurements should match. If you want to be more accurate you can use a machinists dial gauge to measure within 1/1000 of an inch.
If the measurements are off, you need to loosen the trunion bolts that mount to arbor to the table just slightly, then use a dead blow to move the table in the appropriate direction.
Search youtube for "table saw allignment" to find lots of videos showing this technique.
Also, here is a copy of your owners manual:
http://www.homedepot.com/catalog/pdfimages/c2/c2e26e29-35a4-469c-8193-136092afdbd3.pdf
Jun 30, 2012 | Ridgid 10 in. 13-Amp Professional Table...
My electric hedgetrimmers blade moves,but wont cut.
Check the screws or bolts holding the blades together are tight but not so tight that the blades aren't allowed to move relative to each other.
You may need to sharpen the blades. This can be done with a small flat file but is a tedious process and will take about an hour.
Jul 12, 2011 | Garden
I have a Flymo Sabre cordless hedgetrimmer, which has stopped cutting anything although the blades still move. What can I do to fix it?
If there are screws or bolts holding the blades together, check these are tight, but not tight enough that the blades can't move relative to each other. If the teeth aren't sharp, you can buy a small flat file to sharpen them. This is a tedious process and both cutting edges of each tooth need to be sharpened.
May 11, 2011 | Garden
Jet table saw JWTS-10CW2 blade allignment. The blade went out of allignment when cutting some 45 degree angles with blade tilted to right. Blade is in position at front of table but has moved to the...
The table needs to aligned with blase and mier slots. I used a dail caliper to measure distand
ce from the front of blade to rear of blade. Use a piece of tape to mark tooth and use that tooth to measure front and the rotate and measure back. usually there are 4 bolt that hold table. Lossen only 3 and slack off the 4th to help hold table . Use a block of wood and hammer to tap table in alignment. DO NOT GET WILD or you will have more work resetting everything. The alignment is usually of a small amount. Good Luck
Sep 14, 2017 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
The cutting blades on my hedgetrimmer are not "crossing"
worm out bearing housing or eccentric lobes
no fix but a new head or unit
Dec 18, 2017 | McCulloch 18" Electric Hedge Trimmer
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Blade misalignment
The 1590, like several Bosch jigsaws, has a selector switch to choose the type of cutting action. You have to choose the appropriate cutting action, either straight or oscillating, to accommodate the material you cut and the blade you cut with. For instance, if using a very slender blade for clean curved cuts in wood, a slight oscillating motion ( setting II or III) reduces friction on the blade.
If you choose the straight cutting action you get maximum accuracy, but drastically increase the friction because the blade is held firmly to the roller bearing.  A slender blade can handle that for brief periods, (say... less than thirty seconds) in soft, thin wood with a straight cut. In hard woods or engineered wood products ( plywood, MDF etc.) the thin blade will heat up and bend.
You can reduce friction by choosing an oscillating cutting motion, or you can use a larger, sturdier blade. The "Aggressor" blades do not cut as smoothly as the "clean" blades, but they cut faster and are stronger. To cut thick wood ( 4x4 ) or a long cut in engineered material, that is the blade I use. Select number III or number II for 'type-of-cut' and use a bigger blade. See if that stops the "bucking."
Mar 24, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
T-Outliner has stop cutting!
good advice but the best way to align is to know the exact aliment,pay attention to how the blades are set in relation to one another when they cut correctly,and remember this so that next time wont take so long to adjust the blades.
Mar 12, 2008 | Andis 01690 Hair Trimmer
Craftsman 22" Gas Hedge Trimmer Logo
164 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
