Question about Kenmore 12102
Thread constantly breaks
I have changed thread about ten times, adjusted tensions, checked bobbin, cant get it to work.......
instantly the thread breaks every time. no stiches are being made.
i have used this machine a hundred times to do things and dont unsterstand what i am doing wrong.....
please help.
  • 124 Answers
Welcome to FixYa!
Believe it or not, this is usually caused by a bent or burred needle. Since you didn't mention changing it, I think that this is a possibility. Needles should be changed about every 8 hours of operation or more often if sewing heavy fabric. Try it and see.
If my info solved your problem, please give me a FixYa rating. Thanks!
Posted on Feb 01, 2009
My bobbin and thread are constantly breaking. I have the correct thread to needle, but I don't even get one stitch before both break. Tension is on auto; should it be less or more?
is the needle in the holder the correct way ( groove in the needle facing the thread )
Is the needle eye the correct size for the thread in use
remove it from auto tension setting and adjust it your self
make sure that the top thread is between the tension plates and not around the thread behind the plates
the thread tension is close to correct when you need a bit of a pull to pull it along to the needle
is the method of threading to the needle correct as any areas where the thread reverses direction will cause it to break
what do mean that the bobbin is constantly breaking or is it the bobbin thread that is breaking
have you got the thread down the case slot and under the flat spring correctly
the bobbin has to be inserted into the case in such a manner that when the thread is pulled , it flows down the slot freely as the bobbin turns
if the direction is wrong , the thread has to move across the sharp edge of the slot and will cut easily
Dec 21, 2015 | Brother Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Breaking cotton on top and bobbin
Try loosening the tension for that bobbin
Dec 15, 2015 | Sewing Machines
How to adjust tension on a baby lock BL1556
on your bobbin case there should be a tiny screw to adjust the tension of the bobbin thread. loosen that screw if heavy thread, or tighten for thinner thread. Play with it and try getting the correct tension that will continue.
Aug 03, 2017 | Sewing Machines
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
My bobbin wont feed through
take the bobbin out check for debris (pieces of thread, lint, etc.) that may be jamming the bobbin. check under the feed plate for a thread jam or debris. check if your bobbin is wound too tightly. it can happen! then it will keep breaking. the other adjustments are mainly for thread tension- the spool on top. if they're too tight, the thread will keep breaking. you can tell- once they're properly adjusted- by the quality of the stitch. check the bobbin first! if it's too tightly wound, you can probably adjust the winding tension on top. try a different bobbin. if that works then 'rinse and repeat!'.
good luck!
Sep 24, 2009 | White Sewing 1418 Mechanical Sewing...
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Thread breaks off
Where does it break? You change tension at the top via the tension discs the thread passed through, and at the bottom by adjusting the small screw on the bobbin case - the screw on the front part of the spring. Thread size matters as well as needle size. For everyday upholstery I use #69 nylon thread, and "G" bobbins.
If the thread's breaking at the hook you may need to adjust timing. But most commonly thread breaks because of improper tension, threading, needle or thread size.
Mar 22, 2009 | Consew 226R-1
Tension
I answered this a couple days ago but don't know if it went through. I can sew through 6 or more layers of denim with my 226, no problems at all. In my 30 years in the upholstery business I never had a problem sewing leather, vinyl, canvas or multi-layers of fabric. The 226 Consew, the 111W and 211w Singers I had presented zero problems with heavy fabrics - and I don't consider vinyl "heavy".
You need to first of all check threading. If the machine's threaded wrong you're break thread. Also you need to oil under the bobbin case and the bobbin hook and the rest of the parts as well.
Then, loosen thread tension on top by turning the knurled knob that's on the spring that's holding the tension discs. Also loosen bottom tension on the bobbin case by turning the small, left-most screw on the outside of the bobbin case counter-clockwise. Do both with the presser foot down. Pull the thread(s) out and feel the tension. You should be able to pull the threads out with some little effort. Tighten both a little at a time until you get some tension. Run a couple seams and check where the threads meet in the fabric. They should meet in the center. Also check stitch length. If you're using 92 thread (is should be left twist), you should run the machine at about 6 - 7 stitches/inch. I'm running my machine at 5 - 5 1/2 with #69 nylon bonded, and 6 - 6 1/2 with #11 mono.
One more thing; if tension's too loose at the bobbin or top, the machine will jam in the bobbin and thread will break.
Go to www.consew.com and download a pdf owner's manual for free. You need to click on the 224. That machine, the 225 and 226 are the same.
Nov 05, 2008 | Consew 226R-1
Kenmore 12102 Logo
87 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
