Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
Can the speakers be replaced in the Samsung HL-P5085W tv?
The tv makes crackling sounds when the volume is set at a higher volume.
SOURCE: no sound or picture HL-R5067w samsung
alread change the lamp and fan did not work
Posted on Feb 09, 2008
SAMUEL011
  • 39 Answers
SOURCE: How do I replace the digital board for Samsung
Hi
Well i fond this video on youtube I hope it help
http://www.youtube.com/watch?v=0jr_9A5Xd2Q?click=52978
Please rate this post if it was helpful,as I do this for Free.
Regards
Posted on Dec 17, 2009
SAMUEL011
  • 39 Answers
SOURCE: my samsung hl-p5085w is humming all the time and
Samsung is known for bad color wheels and for what you describe it surely sounds like the color wheel bearing if going out on you,you will need to replace the color wheel you can find more help @ fixyourdlp.com and if you want to buy the part you can find it @ http://www.discount-merchant.com/SearchResults.asp?Search=color%20wheel?click=52978 or @ http://www.samsungparts.com/search/search.asp , just so you can be 100% sure you will need to get the part number from the actual color wheel that you already have,
Please rate this if it was helpful,as a do this for free
Regars
Posted on Jan 07, 2010
ladywinn
  • 5138 Answers
SOURCE: No picture on my Samsung HL-R4667W TV.
Its your Lamp if you have sound and no picture.
CK the lamp Fan make sure it is running.
Lamps Prices depend on where you buy.$85.00 up to $300.00 Look on E-Bay under Electronics/ Lamp number-BP
Mats Electronics has them for $99.00
1-800-628-1118
remove your Lamp and look in middle of it,that will tell you if it is busted.
Posted on Mar 03, 2010
  • 336 Answers
SOURCE: TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Posted on Apr 02, 2010
The speakers are making a crackling noise that is not effected by the volume
Check the speakers first. If the voice coil of the speaker has any fault, the speaker should be replaced. Connect an other speaker in place of present one, and see whether the crackling sound occurs with it too. If yes, the audio output board to your TV have the fault, and it should be replaced.
Oct 17, 2012 | Mitsubishi LT-46153 LCD TV
I need directions to replace the DMD\DLP Chip in a Samsung HL-P5085W. Can you tell me where I can get directions/diagrams?
you will need the service info to dissassemble the Set and the DMD chip is usually held in with screws or clamps depending on chassis design. You can get the service info from www.servicemanuals.vstore.ca delivered by download link.
Oct 06, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
I try to get tv 50" Samsung HL-P5085W i want to know if this kind of tv works good
Yes. This is a good set. Picture is good. But keep in mind that Samsung no longer makes this set and stopped making DLP tv"s. Parts are dwindling.
Apr 09, 2010 | Samsung HLP5085W 50" Rear Projection...
My samsung hl-p5085w is humming all the time and
Regars
Jan 04, 2010 | Samsung HLP5085W 50" Rear Projection...
I have samsung hl-p5085w and the bulb shuts off i turn the tv right back on and it works for like 40 mins and does it again any thoughts?
Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Found it here: http://www.discount-merchant.com/Samsung-BP96-00677A-OEM-Replacement-LAMP-BULB-p/samsung-bp96-00677a-lamp-oem.htm?Click=48173 If you've replaced the lamp before it might be the board that powers it ,it's called the ballast.Good luck nad God bless you!
Nov 18, 2009 | Samsung HLP5085W 50" Rear Projection...
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Samsung HL-P5063W speaker replacement.
Here is Samsung service locator where you can put in your zip and then find where to buy your replacment speaker.
http://www.samsung.com/us/support/repairlocation/serviceLocator.do?group=&type=&subtype=&model_nm=HL-P5063W&dType=D&mType=UM&vType=R&prd_ia_cd=02010300&acc_ia_f
Dec 31, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Crackling noise from subwoofer????
sgangsta91,
i think your speaker cannot support the sound that your computer produce. it means to say that, they are not compatible. specially when your computer sound interface that you used is 5.1 or 7.1 interface but your speaker specs is only for generic sound, you really hear a crackling sound and more if you set to higher volume.
but it can help if you only set your computer interface to generic sound or set only in lower volume it can help. because if you continue that way, your speaker can be seriously damaged that even at the lowest volume can hear the crackling sound.
or if you really want a fine good sound system then, buy a speaker that can interface with 5.1 or 7.1 or see manuals of your computer/motherboard. for recommended specs
aclamonte
Nov 07, 2008 | Logitech X-220 Computer Speakers
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
307 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
