Hp dv7-2043cl model NM101UA location of wifi adaptor in laptop so I may replace it.
I have a replacement WiFi adapter but I need to physically locate the current WiFi adapter in the laptop so I may replace it. Is there a blown-up diagram available on web of hp dv7-2043cl model NM101UA or similar model so I can locate WiFi adapter?
SOURCE: wifi - packard bell laptop
I sometimes have the same problem and usually it's because the router somehow looses connection with the laptop. You may require a stronger router/different kind of router. Have you tried to move the location of your router first to see if that could be one of the problems ?
Hope this works for you.
Posted on Dec 29, 2007
rockitman187
  • 2559 Answers
SOURCE: WIFi catcher
You can drive around with your laptop,You cannot look at the indicator and know when your near a "station" .You can however look at the wireless status page and see any available "stations". The led simply says that your wireless is turned on.You cannot do anything with the laptop turned off.You only need drivers if you don't have wireless drivers already loaded.
Hope this answered all your question.
Please rate this fixya
Posted on May 14, 2009
  • 100 Answers
SOURCE: ASUS wifi switch
Make sure that wifi is enabled in wireless switch utility. You can find that in the system tray next to the clock.
Posted on May 28, 2009
adnanbhatti
  • 1188 Answers
SOURCE: I have hp pavilion dv4 laptop . The wifi is disabled by itself!
Your laptop goes into power save mode once the power suppply is disconnected. WIFI consumes a large amount of power so the system shuts it down to save power. You can disable it by going into control panel and power options. There you can change the power settings to allow wifi to run when using battery.
Posted on Aug 07, 2009
SOURCE: my hp nc6000 wifi is not working as no light turns on even
try to reinstall your Wireless network setup
here's the link of your laptop driver
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=367369&prodSeriesId=367367&swLang=8&taskId=135&swEnvOID=1093
Posted on Jan 17, 2010
Error message "A physical WiFi
I believe you just need to reinstall the driver for your Wifi adapter.
Here's the link where you can download the driver for your wifi adapter Click Here. Just click the Download Drivers and Software on the left side and then you will have options if you want to have the website to auto detect your system or just browse for a specific product.
Hope this helps
Sep 21, 2011 | Lenovo ThinkPad R51
My toshiba satelite won't connect to the internet and i get an error message saying its my network adaptors. does this mean its a software problem or will i have to physically remove and replace the...
Hello.
Test your laptop at a different location to see if any difference.
If still the network adapter, first try to update the driver by going to Device Manager, find the network adapter and select update. You'll actually be reinstalling the current driver software.
If still a problem, the network adapter would need to be physically removed and replaced.
Hope this helps.
May 20, 2011 | Toshiba Computers & Internet
Just bought a ASUS 1015 peb netbook- also have a phone router with iwi-fi-cannot figure out how to connect it to the netbook
if you have a built in wifi adapter, open your network connections icon in the control panel with a right click and send a short cut to your desk top, youll probably be using this short cut a couple of times. then left double click on the desk top network connections icon to open it.you should see all the devices in use on your laptop including your wifi adapter if you have one. right click on your wifi adapter, it should have a red x thru it. scoll to properties at the bottom, click on it it will open up the wireless properties. if windows is configuring your adapter youll see a connections tab in the center, click that and the big box at the bottom youll see a add button. click that add your wifi routers info there. if theres no connections tab go to programs and locate the utility for your wifi adaptor because your utility is controlling the wifi. open the utility, add the wifi router info as before when related to windows configuration. you should be good to go.
Jan 22, 2011 | ASUS Computers & Internet
I have a usb wireless adaptor why cannot connect to the internet
look its an ADAPTER an adapter ADAPTS to the internet BUT for the internet you neeed WIFI.. BY a ROUTER Or by your DSL set up the wifi and your ADAPTER WILL pick up your WIFI once they ADAPT you can connect to the internet.. RATTTE
Jul 22, 2010 | Nintendo Wii Console
Is this model wifi enabled
You have not given your laptop specific model number! In any case, the Presario 2200 series of laptop normally come with Wifi adapter as standard. To check, use windows 'Device Manager' and locate the 'Network adapters' node: this will tell you for certain what network adapters are available.
Hope it helps. Let me know how you go or if you need further assistance.
Jan 08, 2010 | HP Compaq Presario 2200 Notebook
HOW DO I TURN ON THE WIRELESS CAPABILITY ON MY HP LAPTOP?
All depends on the Model laptop... Most All DV Series HP Laptops have a physical switch that you turn on and off (a slide switch).. It is located on the front, just under the lip of the touchpad on the left side... You can look on the front and both sides for a WiFi switch...
If you do not have a switch.....
You need to use your Function Key Combination..
The Fn Key is located down by your space bar to the left of it...It is your Function Key....
Pressing this and a corresponding F key (F1-F2-F3-F4.. etc...)
Look at the F keys, You will notice Icons as well on the individual keys.. usually in blue or grey color....
When The Fn (Function) Key Is Held Down - You can acces the secondary key options...
You Should See A WiFi Icon on one of them keys...
Press Fn and the "F" Key that has the WiFi icon Together...
Nov 18, 2009 | HP Computers & Internet
I have lost the manual to my WL-167g USB WLAN Adaptor and I want to connect to a different router I do not know how to set it up to operate the new router. the router is working on the internet with...
The wireless card will find any available access points. If you take the laptop to a location with wifi, the wireless card will find the wifi spot. Just open the wireless software you are using and ask it to refresh the wireless networks and you should see your wifi.
If you don't see your wifi but have confirmed your wireless network card works in other locations with other routers then take a look at your router configuration.
Please let me know if you have any more questions. Thank you.
Sep 29, 2009 | Computers & Internet
Need to extract bluetooth module.
The bluetooth module is normally intergrated with the WIFI. If you open the memory compartment underneath you will see a seperate card which will have 2 wires connected to it black and white..
thats the WIFI chip with the integrated BT.. you'll have to replace that.
Is your WIFI working btw?
Mar 02, 2009 | HP Compaq 6720s Notebook
Drivers for windows vista 64 bit
i want wireless senao engenius driver vista to HP laptop
Dec 10, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Problem in wireless network
what exactly are you connecting too,
Axis Point ???,Wireless Device ???,Wireless Network???
Make and model thanks.
This will help better understand your problem thanks
Jul 25, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
David Payne
David Payne
