Question about Konica Minolta Magicolor 2530 DL Laser Printer
Magicolor 2400W error
My printer has stopped printing, indicating that ALL 4 of my toner cartridges are empty (toner indicator lights are solidly on and error light steadily flashing). All 4 cartridges were replaced August 2008 (1500 sheets for the color, 4500 for the black). I print an average 160 pages a month (minimum color printing) ! Could it really be that all four emptied at the same time? I've also noticed that when I print only black (no color), the ink easily smears. To prevent smearing, I just change one word or a letter to dark blue and the document prints without problems.
Please help! I am school teacher and spending over $400 on cartridges is a nightmare!
This happens to me every few months, I have to do a VERY detailed cleaning of all toner sensors. The knowledgebase on KM's website is actually very good about walking you through which sensors to clean and pictures indicating where they are located. This has fixed me up every time. GOOD LUCK!
Posted on Feb 19, 2009
How to deactivate toner colour errors?
if any toner ends in a printer, then replace it.otherwise error will show continuously.
Apr 22, 2010 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400W toner cartridges not empty
Have you tried taking the toner cartridge out of the printer and shaking it up a bit? Just make sure you do it outside or over a trash can. Shake it side to side.
Sometimes the toner bunches up and you can get some more life out of it by shaking it up.
Hope this helps
Thanks
Mar 24, 2008 | Minolta magicolor 2400W Laser Printer
Will the magicolor 2400w stop if one toner cartridge is empty . If yes can it be bypassed??
Removed each toner cartridge, shake it and replace it.
I don't know if this is the real fix but it worked for me at this time..
Sep 03, 2009 | Konica Minolta magicolor 2400 Laser...
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Installing new black print cartridge
Manually Removing Toner for magicolor 2400W
1.  Hold down the Cancel button for 10 seconds or longer.
2.  With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3.  When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4.  Then hold down the Rotate Toner button again for another 10 seconds or longer.
5.  The Cyan toner cartridge moves into the proper position, so it can be removed.
6.  Remove and/or replace the Toner Cartridge if necessary.
7.  Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
Oct 21, 2007 | Minolta magicolor 2400W Laser Printer
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Konica Minolta Magicolor 2530 DL Laser Printer Logo
271 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
