Question about Samsung RSG257AABP (25 cu ft) Side by Side Refrigerator
My fridge is on but its not cold there is a OFf on the screen.
Seems like its defrosting. how long does this last?
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
My freezer (upper) works but my fridge (lower) doesn't. There's nothing clogging the vent. What could be the problem? Thank u!
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and are not torn or ripped. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the f
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some are behind the cold control cover. Once you locate the defrost timer, slowly turn the screw likeknob in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater (s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can continuity test the defrost heater for continuity or test for 120 volts to the heater(s). If you have no power to the defrost heater (s) you can also bypass the defrost thermostat to see if the defrost heater will come on, jumper the wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater (s) and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
bobicehouse_88.jpg Defrost timer
bobicehouse_89.jpg Defrost thermostat
bobicehouse_90.jpg Defrost heater
Sep 11, 2011 | Sharp Refrigerators
Liebherr KD 900 fridge freezer bought 2001. Both the freezer and fridge are losing temperature, as though it is defrosting and then clicks back on and seems to regulate itself again. This has happened...
The defrost timer sticks in defrost mode and then comes out of it. I've been out of the service industry long enough to not be able to tell you on your model where it is located. Defrost timers on frost free refrigerators are a very common problem.
Oct 11, 2017 | Liebherr KES3660 Stainless Steel...
I have a Teka A-FCI340 fridge/freezer. The fridge is too cold and freezes items put into it. No matter how I turn the temperature control dial it still seems to be too cold.
I had the exact same problem with the same model and mine was just 3 years old. My problems started when I defrosted the freezer. I spent 75gbp on an engineer who told me that I had probably 'spooked' the fridge when I defrosted the freezer, that this particular model of fridge wasn't designed to last longer than 2 years.
I would recommend you check the door is shutting properly (check the screws at the top, it might be just slightly out of alignment).... I turned the whole unit off for over 2 days to allow absolutely everything to defrost (both inside and on the back of it)... within 30 minutes of turning it on, the back of my fridge was already frosted over.
Engineer told me not to waste money calling them out again, and to buy another one...
Oct 17, 2010 | Microwave Ovens
Not getting cold
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Would also appreciate if you could provide us the model number of your fridge so that if the above solution does not resolve your issue would look into the matter specific to your type of model.
I am sure this solution would help you to resolve the issue.
God Bless
Jul 13, 2009 | Whirlpool Refrigerators
Warm fridge
check the fan in the frezer and check the defrost
Nov 29, 2008 | Amana Refrigerators
Refrigerator and freezer not getting cold enough
If the problem just gradually started happening, it's possibly the defrost cycle that's not working right. Fridge doesn't defrost, the cooling system ices up, and the cold air can no longer travel through the fridge.
You can tell that's the problem if you fully defrost the fridge (turn it off for a day), then start it up again. If it works OK for a while, then does the same thing after a few weeks that's what it is. Either way, you need a repair person to fix it, or you need to defrost it regularly, but then what do you do with your food while you do that???
Nov 17, 2008 | Magic Chef CTF2125 Top Freezer...
Kenmore Side by side model # 25357682790
is the freezer fan working?is there frost in the freezer on the walls?can you find the defrost timer?let me know and we can go from there-mike
Oct 15, 2008 | Kenmore 53542 / 53544 Side by Side...
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Samsung RSG257AABP (25 cu ft) Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
