Question about Bosch HBL3420UC Electric Single Oven
Popping and arc-ing in the convection area after turning off oven!  I shut off power immediatly!
  • Bosch Master
  • 3,463 Answers
I would suggest that you check the oven element, as this is about the only thing that could cause the problem.
Plz rate my comments.
Thanks.
Posted on Jan 20, 2009
My electolux superba convection oven is not maintaining it's temperatures?
Heating elements cold be going bad look at them with a flashlight if either of the elements look thinner than the rest of it then it needs replacing before it goes out completely. With aloud bang a bright arc flash and smoke. Very scary. There's a metal tag on the inside of the oven door jam.write the model and serial number down. Shut off the circuit breaker for the stove should be a 50 amp double breaker. Remove 2 small 1/4 inch screws. Slide the element out straight to you. Remove the 2 wires with the same 1/4 inch nut driver keeping the wires separated .Do Not turn on the circuit breaker till the new elements are installed! !! Use the model and serial number to get your new elements first.
Sep 26, 2014 | Ovens
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 membrane....plus labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
How do you unlock the door to a convection oven?
Here is what you do when the convection oven door locks automatically. Where the stop/clear button is, you will see a lock symbol that has a number 3 on it. hold the stop/clear button down for 5 seconds and it will unlock you convection oven.
Nov 18, 2009 | Kenmore Ovens
My dacor oven model ECS130SBK is very slow to heat. Sometimes reaching the desired temp. after a long wait. Sometimes it never gets there.
I found the bottom element was not getting any power by using a volt/ohmmeter and a test method described elsewhere. (Shut off power, hold down COOK TIME while turning on power. then within 30 seconds press each mode you want to test and only that element/fan/etc will turn on. Cancels by itself after 30 sec.)
I traced the wire back to the relay (wire checked good) and there was no power getting through the relay although it clicked. Removed the relay board to replace it and found a cold solder joint on the "out" terminal with obvious past arcing carbon. Cleaned and soldered the pin and the oven now works normally.
WHY THE SLOW TO HEAT? The oven turns on all the elements to preheat faster and when it reaches your set temp it beeps and now only turns on the element you selected to maintain the temperature. (Bake or Convection) Our malfunctioning ovens would then cool since the element is not working properly and it must go back into preheat and keep cycling.
BY THE WAY- Don't ever use 4 hours on self clean it kills the boards and/or display. I also put a house fan in front of the oven and blow it into the lower grill to take away some of the heat on the two boards. Learned the hard way!
Jun 08, 2009 | Dacor ECS130 Epicure Electric Single Oven
Oven door won't unlock
There is a high limit safety thermostat that acts as a one time fuse. If the outside of the oven gets too hot it will shut down power to the elements. The safety is on the behind the back wall of the oven (depending upon the model) the wall oven will have to be pulled from the wall and the back cover removed. Be sure to shut off the circuit breaker before removing the back cover. The thermo fuse should be located slightly to the right and up from the convection fan port. The door will unlock once the power is restored to the circuit. There should be a wiring diagram inside the top control area of the oven that will help your efforts.
Mar 12, 2007 | Kenmore 47813 Electric Double Oven
Bosch HBL3420UC Electric Single Oven Logo
71 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
