Replaced the drum, printer still says replace drum and print quality has not improved.
SOURCE: replace drum, still says replace the drum and now it won't print.
Did you reset the drum counter?
When you
replace the drum unit with a new one, you need to reset the drum unit
counter by completing the following steps:
I hope this helps.
(if you did the reset, you may need to talk to Brother Support. I'm assuming you used a Brother drum and only handled it by the handles.)
SOURCE: toner light still on after replacing with a new one
Drum counter usually has to be reset.. Check user manual or go to Brother's site if you want to drive yourself crazy Ed
SOURCE: Replace Drum Soon Message
Read your manual. There is a counter that goes off, that can be reset when you change the drum.
With power on and front cover open press set, then select reset drum
SOURCE: Replaced both toner and drum- prints too light
remove drom and toner, in base of machine is a glass slit, clean it.
SOURCE: Printer is printing BLACK PAGES
Solution from brother
