Question about Maytag 24 in. MDB9750AW Dishwasher
Maytag dishwasher legacy 300 quiet series skips steps in the program
When i push heavy wash it cycles for about a minute and then goes direct to the rinse cycle. Is there a sensor that I can change to fix my dishwasher?
3 Suggested Answers
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Posted on Dec 19, 2009
SOURCE: Maytag dishwasher legacy 300 quiet series
I was so impressed with the advice on this website, I thought I would take a stab at this. The difference is, I will include all the steps, so if I go into a little too much detail for you, I'm sorry, but I felt a few things got left out that needed to be said.
Tools Needed: screwdriver with t-15, and t-20 torx bits (available at any hardware store), and a pair of pliers. Also I used a headlamp so I did'nt have to hold a flashlight with my teeth.
step#1- Clear a spot on your counter or kitchen table and remove both the lower and upper racks from your dishwasher. The lower rack just lifts out, the upper you will find two light blue plastic caps that once removed will allow you to slide the rack off of the metal slides. Next, the long L shaped spray bar that goes up the back and across the top needs to be un-clipped and removed, 2 clips at top and 2 clips at the back. It might take a little wiggling but that spray bar slides into the top cover, once unclipped push back at the bottom and tilt the upper part toward you, it should come out fairly easily and give you wide open access to the cover. Next you want to remove the plastic nut that holds the spinner in place, using your pliers turn it counter clockwise, it should loosen fairly easily, and remove nut and spinner. Next with either a T-20 or T-25 torx bit, remove the 3 screws that hold the outer cover in place, notice the direction of the tube that plugs into the spray bar, make sure it goes back in the same way. Now remove the T-15 screw that holds the black grinder cover in place and remove screw and cover. Now remove the 6 screws that hold the inner cover in place and remove the cover. You can now see what all the fuss was about, mine included a piece of pistachio shell, a bay leaf, and a cherry pit. Once it's all cleaned out, just reverse these steps and be ready! You have just earned your place as your homes resident handyman or woman!
Posted on Jun 14, 2010
Maytag dishwasher legacy quiet series 300 clean light stays on after cycle is over
That light will remain on until you remove the dishes that are in there so that you know what is inside is clean and not dirty.
Jul 04, 2017 | Maytag Dishwashers
My dishwasher the maytag quiet series 300, will not respond to the start button
Find your circuit breaker for your dishwasher and turn it off for 3-5 minutes. Turn it back on, then turn on your dishwasher. If this works, after the complete cycle of your dishwasher, you have to turn it off manually by pressing "on" botton then press it 1 more time to cancel; this will turn off. The defect is, probably the moisture built up in the control board causing it to ground some of the connections. Suggestion for the manufacturer, insulate the control board to prevent absorbing moisture.
Jan 04, 2013 | Maytag Dishwashers
I have water left over after each wash and it is really cloudy? I use the right amount of dishwasher liquid, etc. It has hot water. When I first got it about 2 years ago, it did not have this issue. I...
try running your disposal for a few minutes and then run through the rinse cycle. mine does this too sometimes and i just need to clean my disposal in my sink as some stuff gets caught up in it.
Oct 05, 2010 | Maytag 24 in. MDB9750AW Dishwasher
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Oct 12, 2009 | Dishwashers
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Maytag 24 in. MDB9750AW Dishwasher Logo
65 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
