Question about Panasonic Home Theater System System
Wont respond When i turn it on it says F61 then shuts off before it did this it made this wierd buzzing noise? What do i do please help
  • Highteck Jan 20, 2009
    Same problem on Panasonic SA-AK78, changed the output IC501 and still F61 is there. I bought the electronic layout schematic, there is a small variation between the circuit I have and the one showed on the schematic.
    So I am still investigating this problem.
  • Highteck May 11, 2010
    And if the fan does not turn on power up??
    Power supply voltage flow is hard to follow as it goes to 3 PC board for either validation or then voltage reduction or regulation.
  • 336 Answers
Check that the fans are working they should start on power up. If they do its probably the output IC. (not cheap around $100) for the part.
Posted on Jan 19, 2009
Won't turn over... just makes a clicking sound... and a wierd humming sound.
Try cleaning your terminals at the battery, even if not corroded. In my years as an alarm/radio installer I have come across this problem constantly, especially on GM vehicles.
Jun 21, 2012 | 1995 GMC Sonoma
What does f61 mean?
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 16, 2011 | Panasonic SC-AK18 CD Shelf System
1998 Lexus gs300 at idle Very loud buzzing type noise from engine
check brake fluid level.
master cylinder might be of interest, but i would check the fluid level first
Apr 08, 2010 | 1998 Lexus Gs 300
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
I changed the bulb in my tv and it was working for a few days. Now I get audio but there is a wierd electrical clicking noise which made me think the new bulb broke but I still have a green light on the...
In this case there are two possibilities of what part is the one causing the issue, it coul be a ballast because of the clicking sound that caused the tv to shut off, and that buzzin sound is for your color wheel that it might not be working anymore, discountdashmerchantdotcom free troubleshoot
Jul 24, 2009 | Mitsubishi WD-65733 65" HDTV
I have a panasonic SA-PT750 and when i turn it on all it says is F61 before this i was playing music on my ipod using it and started to make a wierd buzzing noise. Please help me!!
Hello,I have a sa-pt1050.I says in my manuel if this is flashing to check speaker cable connections,if this does not fix it consult your dealer
Jan 19, 2009 | Audio Players & Recorders
F61 error
If memory serves me correctly, the F61 message is teh shorthand for protect mode. There is a problem with the output section that is being detected. The unit shuts down to prevent additional damage to either the amp section or the speakers. I'll look up your specific model for more details. In the meantime, check the speaker wires to be sure that they are not frayed and crossed.
Dan
Apr 08, 2008 | Audio Players & Recorders
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
Panasonic Home Theater System System Logo
135 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
