Question about Sharp Office Equipment & Supplies
Program sharp ar-M207 fax header - Sharp Office Equipment & Supplies
vegakitten20
  • 685 Answers
SOURCE: Hooking up my Sharp AR-M207 Printer to my computer
yes you can put in the serial # of the printer and there site will tell u what u have to do
Posted on Nov 10, 2008
tehnik_bdg
  • 91 Answers
SOURCE: Sharp AR-M207 Error Message
H4-00 means heat roller low temperature detection. It usuallly caused by 3 things :
1. The machine hang : You simply reset the error code by pressing : # * C * then input 14 then start.
2. If the error still displayed, open the side cover, feel the fusing unit ( don't touch, it is hot ), if the
fusing unit feels cold then the problem is the heater lamp ( inside the upper heater roller,
connected with anti heat cable and big connector ), you should replace it.
3. If the fusing unit feels warm or hot then the problem is the thermistor ( connected with small cable
and connector ), replace it.
Posted on Mar 04, 2009
  • 54 Answers
SOURCE: message H2-00 in sharp ar m207
You have an open Thermistor in the fuser unit or the code is false caused by power surge. To reset it, press P*C* and hit 14 start, then hit either ok or start again and machine chould reboot and clear code. If code returns then the thermistor is bad. You will have to have your local dealer replace either the themistor or the entire fuser unit.
Posted on Apr 17, 2009
SOURCE: Sharp AR-M207 with a F9-00 message
f9-00 means the ar-nb3 and or eb9 print control boards failed to recive all packets involved in a perticular print job. weither its 1 page or 100 pdf tiff raw etc does not matter.
as a printer service technician i can ashure you there is no known all inclusive fix at this time. cycling the machine's power will clear the code.
Posted on Mar 09, 2010
hamzaskilltd
  • 316 Answers
SOURCE: SHARP AR--M207 Error L4-11
1. Main motor lock detection
2. shifter motor trouble
Posted on Jun 01, 2010
I need a printer software to enable me print with my window 7 software
To help you install printer software for Sharp AR-M207, please find the link given below and find the topic mentioned as 'Software' and select Windows xp:
http://www.sharp-cee.com/cps/rde/xchg/scee/hs.xsl/-/html/product_details.htm?product=ARM207
GuruAid.com
Mar 31, 2016 | Sharp Used AR-M207 Copier Printer Scanner
I need a software that can enable me print from my 26 bit computer and my copier AR-M207 PHOTOCOPIER
You can download a printer driver from here.
http://www.sharp-world.com/support/download.html
Microsoft is ending support for Windows XP so I would suggest updating your operating softwaere.
Mar 09, 2016 | Sharp Used AR-M207 Copier Printer Scanner
Is this the correct place to post questions for Sharp AR-M207 ARM207 Printer/Copier/Scanner/Fax?
Sir, normally you can not get firmware for any copier/printer unless you have access to the companies Secure servers, which house the firmware, Companies like Konica Minola, Sharp want to protect their software, must be a dealer or Corp Technician, Drivers are a totally different story they are normally free at the company web site, and are the best place to go for the most up to date drivers Windows 8.1 10 64 bit etc.
Jan 02, 2016 | Sharp AR-M207 All-In-One Laser Printer
SHARP AR-M207 displaying an optional fax kit is not installed. what should i do?
is there one in the machine. does it have the phone cord hook up on the side of the machine if not you do not have the fax capability, it was an option on this model. you would have a hard time finding one now. if it is there the fax board is damaged and would need to be replaced but like i said you would have a hard time finding one.
Jun 28, 2014 | Sharp AR-M237 Copier
Serial number for AR-M207 Sharp Printer Scanner Fax
The sharpdesk ser # is located on the documentation that came with the installation disk.
Dec 29, 2009 | Sharp AR-M207 All-In-One Laser Printer
My sharp AR-M207 all-in-one does not send or recieve fax
dear sir good day the link http://support.sharp.net.au/drivers/driversearch.asp contain the driver for machine but the problem may happen from the tel line or from other fax sender ... so please first reinstall the driver and try to send or receive fax from other one thank you and good luck
Dec 26, 2009 | Sharp AR-M207 All-In-One Laser Printer
AR-M207 default paper tray for fax
push"special function" button, then select "key op prg", then "ok", then enter pin (default is 00000), then select "fax", then "ok", then select "rcv function", then "ok", then "tray selection", then "ok". The rest you should be able to follow your nose.
Feb 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
