Question about Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher
How to replace the timer JDB1090AWS Stainless Steel Built-in Dishwasher
Dishwasher is not draining. Pulled the unit and checked all the hoses, removed debris reconnected and it would only wash would not advance into cycle. So how do I replace the timer, where is it located and I also can only use the super scrub cycle, none of the other cycles light up on the board.
SOURCE: jenn_air model #JD8910AWS won't drain
I was having the following symptoms: If I hit the drain button, it would stay at 2 minutes and just click on and off. If I hit the rinse button, it would rinse all 9 minutes OK. It would always stick in the middle of a full cycle and just start clicking.
I just fixed it. I shut off the circuit breaker, opened the door up (all torx screws from inside of door) to get the the upper controls. One lead (of two) of a capacitor (square blue component) had actually worked itself out of the control board. I cleaned it up and resoldered it in. All better now - for now.
Posted on Dec 06, 2007
SOURCE: Jenn-Air dishwasher jdb1100aws problem
I had the same problem , needed a seal kit w/ alignment tool.
repair part # 99003341.
Posted on Mar 16, 2008
SOURCE: jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Posted on May 19, 2009
  • 22 Answers
SOURCE: Jenn Air dishwasher leaking
the emptying valve is underneath in the middle normally and it is what the drain hose connects to on the dishwasher. The drain hose itself is connecting with either a c clamp or hose clamp, check to make sure it is tightened all the way. Also do you have an idea of what part of the dishwasher the leak is coming from? If it is not the drain valve, then check to make sure it is not leaking from the door itself, as the door just has a rubber gasket that seals it and it might be that the gasket is bad. If it's not the door and not the drain valve, it could then be coming from the drainage pump or the motor for the dishwasher, which means the seal is broken and the motor or pump would need replaced. If you are unsure of how to do so then i would contact a repair technician to fix it for you.
Posted on Jul 19, 2009
SOURCE: cannot select any wash cycle but quick wash.
I had this same problem and being an electrical engineer, I decided to see what I could fix before replacing the board. The symptoms were the only cycle I could run was the QUICK WASH - no other cycle buttons responded.
I took the inside panel off and the cover plate off of the circuit board - just a few screws. Nothing on the PCB look scorched or burn and the silicone protection looked to be in tact. But I got it fixed - see below:
Remove power to the dish washer. Follow the ribbon cable from the top panel to the circuit board. Push back the white slider latch and pull the ribbon cable out. Using a knife edge, softly scrape off the connections which face the top side. wipe off with a towel when done and push back into the connector. make sure to pull the white slider latch back down to secure the cable.
that is all it took and we are back to washing dishes! Hope this helps.
JC
Posted on Apr 05, 2010
Se code Samsung DW80F800UWS What should I look For?
Theres a 5E I can't find a Se
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Nov 22, 2014 | Samsung 24 " Built-In Top Control...
All the water did not drain at end of cycle
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 26, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Water wont drain
Check sink drain and drain hose for restriction
Check the drain valve
Check the drive belt
Test the timer motor
If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Before attempting any testing or repairs unplug the dishwasher or shut off the power.
Jun 18, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Jenn-air dishwasher jdb1090aws wont drain
Most common issue on this model is the drain motor itself. More times then not it gets clogged with debris. Pull the unit out and remove the three screws that mount the pump to the bottom of the dw.
take the hoses off and clean the drain motor out. It will fix this issue I have seen it more times then you could imagine. Good luck with your repair friend
May 19, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Dishwasher always has a nasty odor when you open the door
check the drain hose connection from the dishwasher to the main drain under the sink , it should be connected above the trap . hope this was helpful
Jul 11, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Drainage problem
I had similar problem and rerouted the drain hose like papps54 said. I still had the condition and decided to pull out the drain hose completely to see if there was any debris trapped inside the hose. There was! I removed the hose from the machine completely, cleared out the debris, and let the hose soak in white vinegar overnight. In the meantime, I looked back up the drain outlet and found evidence of debris lodged in there as well. I didn't completely dismantle the dishwasher at this point but I did eventually clear it out as well as the drain filter located inside the dishwasher. After reassembling the drain hose and dishwasher, I cleaned it with baking soda for three nights and now it runs very well with no odors. Runs quieter as well.
Oct 10, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jenn-air Dishwasher won't drain water from base
This happened to me after installation. they had installed a one way valve backwards in the drain line and had to reverse it.
Sep 03, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Bosch SHY56A05UC/14
There is a pass through the lower back side of the dishwasher that also has a restraining device to prevent drain hose from being pulled off of drain pump. After passing hose through this opening, connect hose to drain pump. Note: there is another restraining device built into lower plastic housing which has a finger notch to accept hose and keeps the drain hose engaged in to drain pump by not allowing hose to back out of drain pump/ hose interface.
Dec 01, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher Logo
57 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
