Question about Ingersoll Rand Electrical Supplies
Max amprage G7VE ingersoll rand generator - Ingersoll Rand Electrical Supplies
2 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: IR G7VE Generator Manual
The best place to obtain manuals at a discount price is -
repairmanual.com
Hope this works for you.
Posted on May 09, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Why our g25 ingersoll rand mobile disel generator when start it cause overspeed and shutdown immediately
Check the mag pickup screwed into the casing where the flywheel is. Check for dirt and metal chips
Oct 06, 2014 | Ingersoll Rand Used Towable G25 21kw...
Oil seperator
Get the model and serial number located to the right side of the fuel tank 1/2 way up on the radiator and call someone who deals in Ingersoll rand (now Doosan). If you remove the old one you can read the numbers off the bottom of it.
Aug 29, 2013 | Ingersoll Rand Electrical Supplies
What the maximum working torque for a Ingersoll Rand 1/2 2705P1?
Ingersoll Rand 2705P1 1/2 inch 40-200 ft lb Industrial Duty Impact Wrench
Max Torque 400 Ft-Lb
Pneumatic Impact Wrench, Industrial Duty
Pistol Grip Style
Standard Anvil
Square Drive Size 1/2 In
Torque Range 40-200 Ft-Lb
Average CFM @ 15 Second Run Time 4.2
CFM @ Full Load 23
Max Bolt Capacity 5/8 In
Free Speed 8500 RPM
Pin Retainer Type
Required Pressure 90 PSI
Air Inlet 1/4 In
Min Hose 3/8 In
Overall Length 6 3/4 In
Weight 2.55 Lbs
Country of Origin: USA
CR 4Z942
Mar 28, 2011 | Ingersoll Rand Air Tools & Compressors
Where can I find a oweners manual and spec. sheet to download for a ingersoll rand g80 generator ?? I am wanting to wire a outside box with several plug on it.. 120v
Ingersoll Rand generator business was purchased by Doosan so you could probably email them and ask for the manual. Here is their web site:
http://www.doosanportablepower.com/americas/Pages/home.aspx
Here is the generator info
http://www.doosanportablepower.com/americas/products/generators/Pages/PowerSource%20G80.aspx
good luck
Mar 06, 2011 | Electrical Supplies
What is the spec on a ingersoll rand type 30 model 15
Hope this is sufficient information:-
Two-stage Type-30 replacement compressor pump for Ingersoll Rand Type 30 Reciprocating Air Compressors. U.S.A. Max. PSI: 175, HP: 15, Flywheel Diameter (in.): 18, Total Cylinders: 2, Bore Diameter (in.): 5 1/2 and 3, Stroke Length (in.): 4
Jan 25, 2011 | Garden
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
repairmanual.com
Mar 25, 2009 | Electrical Supplies
Electrical Supplies Logo
Top Ingersoll Rand Electrical Supplies Experts
cwradio73
Tom Chichester
Rhonda Webster
Rhonda Webster
Are you an Ingersoll Rand Electrical Supply Expert? Answer questions, earn points and help others
