Question about Behringer Fbq6200 Ultragraph Pro Equalizer Free Ups
How do I connect my behringer fbq6200 to my vsx-94txh reciever?
Receiver is a pioneer elite.
  • 110 Answers
Believe me when I suggest NOT to do this. It's not that it can't be done, but you're really not going to help anything unless your speakers are simply terrible to begin with.
If you desperately WANT to do it, then you would run it through the "Tape IN/OUT" RCA jacks on the back. For it to work, you will have to keep your "Tape" in "Active Status."
Posted on Jan 16, 2013
Where do you connect a midi controller on a Behringer Xenyx 1204usb mixer?
You can connect where it is possible. I hope you will understand.
Aug 04, 2016 | Behringer Music
I cannot hook my Behringer mixer to the Pioneer EFX 500 it's not working
I presume you are using the send and return inputs on the EFX500.
Make sure the effect selector, CH Selector and EF On/off are set right. then use these in the insert chain of the mixer for the channel/bus/sub you want to use the effects on. Remember on the mixer it will be tip send and ring return. It would be useful if you said which behringer mixer (they make an awful lot of them from complex digital to simple DJ) and what you are trying to do with it.
It is clearly explained in the Pioneer manual under basic connections. If you are a DJ you may not be familiar with the Insert concept so get yourself down to a professional sound/PA outlet or Radioshack / Maplin and ask for a pair of insert leads.
May 23, 2016 | Behringer Music
I have a Behringer B1 Microphone and a Behringer 1202 Mixer. I want to know how to connect both of these to my Yamaha Home Theater receiver so that I can sing karaokes from the computer, Please help
You'll need to connect both your PC and the Mic to the mixer, you'll need phantom power switched on at the mixer for the mic to work, you then take the two track out to the Aux input on the receiver.
Jan 30, 2014 | Behringer XENYX 1202 Premium 12-Input...
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Power supply men ded FBQ 6200 9-0-9 ya 12-0-12
what is the problem the power supply is broken? if so go to your local music shop and buy a new power supply there usually universal
May 08, 2011 | Behringer Fbq6200 Ultragraph Pro Equalizer...
How do i hook up my Ultragraph Pro 6200 equalizer to my Europower PMP5000?
You use special "insert cables" to insert the EQ into the path from teh mixer to the power amps. Thee cables have three 1/4 inch jacks and are a Wye type cable that connect the TIP of the TRS jack to the TIP of the plug to be plugged into the OUTPUT of the EQ channel. A second cable ties teh RING of the insdert jack into the TIP of a plug that lugs in the INPUT of the EQ. You need two of these special cables for stereo operation.
Apr 30, 2011 | Behringer Fbq6200 Ultragraph Pro Equalizer...
Trying to connect to a karaoke reciever
I don't know what you are trying to do but if you can plug ho! let say a CD player, than plug the KARAOKE machine in the same place...
Be more specific in your question pls...
Apr 10, 2011 | Behringer Europower Pmp5000 Powered Mixer...
I've recently purchased the NI USB Guitar Link, which comes with two Behringer discs. I'm having problems installing the Behringer iAXE (volume 3) software. Couple of things to share: 1. When I attempt...
If you get beyond the 32/64 issue, check the audio setup for your audio device in your windows control panel. If your USB interface both recieves from your guitar and sends audio to your external amp, make sure BOTH the input and output to the USB are listed as the in and out in the "VOICE" tab when you go to the control panel and "Sounds and Audio device properties".:
Nov 22, 2010 | Behringer VT250FX Virtube Guitar Combo...
I have a pioneer djm mixer 400,I hooked it up to 2cdj mk1002. I want to run them through my pioneer reciever.which is a vsx 1020.im having a problem.IT works okay,if i run the cd player directly to cd...
If your CD player works hooked up to the DJ board, then try hooking the line out of the board into a auxiliary in or line in in or record in on your receiver using the appropriate cables.Try the CD in first and if there is too much signal then use the CD/Tape in. You need to match the output signal of your board to the input signal of your amp. Hope this helps.
Oct 22, 2010 | Pioneer DJm 400 Professional DJ Mixer
Behringer djx700 pro 5 channel mixer
Always check your cables and connectors on them to make sure the cable is good and the connectors are not loose. This sounds like a bad cable or connection between the line output of your mixer and input to your stereo.
Apr 23, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer Fbq6200 Ultragraph Pro Equalizer Free Ups Logo
52 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
