My washer (a Maytag Epic Z has been making noise and not finishing cycles. I'll start it and go to unload it and it'll read 5d on the display. What is going on?
Try checking this link:
http://www.fixya.com/support/t6154548-error_code_sd_mean_maytag_epic
which I found with a google search. Note that this is an over-suds error, and should go away after a while one the bubbles settle down.
Posted on Jan 05, 2013
SOURCE: washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Posted on Dec 26, 2007
  • 409 Answers
SOURCE: maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Posted on Oct 03, 2008
SOURCE: Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Posted on Dec 31, 2008
sivaranjini
  • 241 Answers
SOURCE: Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Posted on Jun 22, 2009
  • 12 Answers
SOURCE: Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
Posted on Oct 04, 2009
No I have a code 5d what does that mean on A Epic Z front washer
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 03, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * EpicĀ® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
The front end load washer door wont open as there is water still in washer and not operating. what to do ..thx
Hi, Make sure it is plugged in properly, and let the cycle finish correctly. Try advancing the cycle control knob ( if it has one). I need a bit more info...
Feb 18, 2011 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic front load washer: Control lock on and won't reset.
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Noise when high speed spin cycle
maytag washer makes a noise when washing or spinning. sounds like a screw is stuck or maybe a bearing is going. It is getting worse each day.
Dec 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
My Maytag epic he has F6 code
What is the model number of this unit. Should be inside the door on the frame. If you take off the bottom panel, there is a tech sheet in there that will tell you what that means. I don't know that one off the top of my head and I can't get at my work P.C.right now. It'll give good detail of what to look for on that tech sheet Let me know if you have any questions.
Mar 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Nov 29, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
