Question about Life Fitness 9100 Elliptical Cross Trainer
I have life fitness elliptical 9100 and the motor not work
I thing the screen have problem
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
Posted on May 01, 2009
  • 11 Answers
SOURCE: hi i have life fitness 9100 hr. it is not
Could be a number of reasons - first to check would be the small micro switch behind the red "stop" button. these sometimes go faulty and will reset the machine at data entry
Posted on Apr 27, 2010
ercupa190
  • 12223 Answers
SOURCE: I have a Life Fitness 9100, and the display is
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
Adjust and clean very softly.
Posted on Nov 22, 2011
ercupa190
  • 12223 Answers
SOURCE: What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Posted on Oct 16, 2012
    ercupa190
    • 12223 Answers
    SOURCE: how do i get the hours info from a life fitness 9500 hr elliptical
    go to the MENU, and see the details.
    However your must read your instr. manual and see how to enter.
    God bless you
    Posted on Dec 05, 2012
    Display not working. hasn't been used for over a year, is it the battery
    The battery is definitely the #1 culprit in this situation. When you use the machine, you actually help keep the battery charged. When the machine is not in use, it gradually loses its ability to hold a charge.
    Video about How to Test Battery
    Feb 14, 2014 | Life Fitness 9100 Elliptical Cross Trainer
    Chances are, if it has not been used in over a year, the battery would need to be replaced. You may be able to recharge, but more than likely the battery will not hold the charge long, if at all.
    Repair Parts for LifeFitness CT9100 Crosstrainer Ellipticals SPORTSMITH...
    When running get error message your pressing on the board too hard?
    RUN the software calibration for easy diagnostic and fix it. Read you owner manual and follow the steps.
    God bless you
    Nov 13, 2013 | Life Fitness Lifefitness 9100 Hr Treadmill...
    Life Fitness 9100 Elliptical Squeaks
    You can use the link below to purchase a suggested form of lubrication. You may end up needing to replace a bearing or bushing.
    Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
    Nov 24, 2012 | Life Fitness 9100 Elliptical Cross Trainer
    Just got a used Life Fitness 9100 treadmill. When I turn it on and press sstart the display says enter weight. Before I can enter my weight and press start it resets itself back to the enter weight...
    this problem is due to a false in the terminals that connect with the microswitch, you must remove the screen and back-side only remove the screws and tighten the terminal could also apply contact cleaner
    Aug 07, 2010 | Life Fitness 9100 Next Generation...
    Life Fitness 9100 Elliptical Cross Trainer Logo
    53 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Howard
    Howard
    Electro Med Services...
    Matt Olenzek
    Matt Olenzek
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
