Question about Dell 3100MP Multimedia Projector
Power supply fuse - Dell 3100MP Multimedia Projector
  • Dell Master
  • 6,694 Answers
HI,
Do you need to know the rating of fuse used in the power supply. Or do you mean that Power supply is not working.
Posted on Jan 04, 2013
  • kennyh_tanak
    kennyh_tanak Jan 05, 2013
    Sorry, I haven't used FixYa very much and I was just trying to look at other 3100MP projector issues and solutions. I already replaced the fuse with a compatible one, I was just looking around to see what other kinds of problems there were. Thanks for the reply though.
How to replace sony vaio pcvl640 fuse?
This is a fuse in the power supply, you will be sure to discharge electricity before opening the power supply it is dangerous. You start by taking all of the screws out of the power supply then gently remove cover of the power supply, there is a small fuse like you would use in your car located near the back of the power supply. Simply take a wooden object small enough to prize the fuse out and replace with a new fuse. Then assemble the power supply and replace into the computer.
Jun 20, 2014 | Sony VAIO PCV-L640 PC Desktop
Location of fuse in Intelligent Module
Fuse panel B contains fuses that supply power to washer functions. 25A fuses 34 and 33 and 30A fuse 32 supply power to the vehicle electrical system control module. 30A fuse 38 supplies power to the wiper motor control module. 5A fuse 19 supplies power to the rain/light recognition sensor. 30A fuse 36 supplies power to the headlight washer relay. 10A fuse 15 supplies power to the instrument cluster control module for washer fluid level sensing. 10A fuse 13 supplies power to the windshield wiper/washer switch in the steering column electronic systems control module. In addition, 5A fuse 20 supplies power to the washer nozzle heaters. Troubleshooting all this could lead to an answer.
Jan 28, 2014 | 2007 Audi A6
Wii wont power on
HI. this is a power supply issue. Your unit is equipped with an external power supply unit. This box incorporates all the necessary AC current regulators, and transfer agents to run the Wii. There are ,also, some protection circuits as well. These are in place to protect the unit from surges are unstable AC spikes as well. There is a fuse that is located inside the power supply box. Simple unplug the power supply, and gain access to the fuse, by removing the outer cover of the power supply unit. there are a few screws,(on the bottom), that hold the top cover. remove the screws, and open the power supply unit. this will expose the fuse. Kindly, inspect the fuse. if it shows signs of trauma, and it is blown, simply replace the fuse.
Now, if the fuse shows no signs of trauma, or burn marks, this will confirm power supply circuit failure. This will require that you replace this damaged power supply unit asap.>>
Dec 27, 2010 | Nintendo Wii Console
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
Where is the power fuse located
fuse is located at the power supply section.to get to the power supply you need to remove the back cover of your monitor..after you remove the cover you can see the power supply..and the fuse is place on the pcboard and there are two fuses the primary fuse and the secondary fuse....be careful when replacing the blown fuse...do it only once once you replace the fuse and blown again there is a problem on your power supply...replace your power supply with a new one...
hope this could help you...goodluck!
your rate is important to this help tnx..
May 11, 2010 | ViewSonic N2751W 27 in. LCD Television
Fuse for gx150 power supply
The fuse is located inside the ATX switch mode power supply and it is solder onto the circuit. There are dangerous voltages inside this power supply. I suggest you get a new switch mode power supply because failure of a component inside the power supply has caused the fuse to blow and replacing the fuse would most likely not fix the power supply.
Apr 03, 2010 | Dell Computers & Internet
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
F 450 instrument cluster has no power and is inop need to trace wires to power source
Interior fuse box fuse no.33(15amp) supplies power in run/acc postion to BK/PK wire pin 19 of cluster.
Interior fuse box fuse no. 45(10 amp) supplies power in the start or run postion on the RD/YE wire pin 20 of cluster.
Interior fuse panel fuse no. 41(10amp) supplies power to the battery saver relay on LG/OG wire pin 11.
Interior fuse panel fuse no. 35(10amp) supplies power to interior lamp relay on BK/LG wire pin 12.
The last 2 are hot at all times.
Apr 11, 2009 | 2004 Ford Super Duty F 450
NPS-180EB A POWER SUPPLY SYSTEM DAMAGE DUE TO OVER VOLTAGE
well first is there a fuse you state fuse available not that one is there -----the surge didnt blow the breaker or fuses either if currant made its way to your components --as to why fuse didnt blow --- no fuse ---surge came through ground --surge blew something before fuse blew your case blew power supply
Jul 21, 2017 | Gateway 180Wt Power Supply NPS-180EB...
Blows fuse with no load
Sure sounds like your power supply has a short and should be replaced.
Oct 30, 2007 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
Dell 3100MP Multimedia Projector Logo
97 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
