Question about Hype HY-2004-BCT Briefcase USB Turntable/Vinyl Archiver with Built-in speakers - Rip Your Old Vinyl to MP3
Turntable won't spin
Ordered this one off of Ebay in the "new" category, so I thought it'd work perfectly once opened... not the case. I turned on the power after placing a record in place and like the manual said, "The turntable will begin to spin when the arm is moved toward the record." When I did that step, nothing... I tried a different speed, same result. I have looked at other complants about other turntables, is it worth the risk to open it up and fix the problem or should I send it back with a negative review?
KitchenAid Microwave KHHC2090
Remove the relay case and gently file the points until clean with a miniture file set from Radio Shack, and spray the points with electronic cleaning spray also available from the same location, try this if new relay won't work.
Aug 01, 2012 | KitchenAid Architect Series II KHHC2090S...
Why won't HP2550 printer work? Trojan Horse?
it is a virus to get into your money
if you have a good security system installed , try running a deep scan that checks everything and removes ay malware or virus problems
Mar 03, 2017 | Amyuni Technologies Amyuni PDF Converter...
The machine appears to be stuck in a wash cycle. After unplugging the machine & plugging it back into an outlet you have no indicator lights. The only button that has a response when pressed is the...
this machine sounds to have a computer board problem I have a calypso washer also and i had the same problem so I ordered both computer boards and replaced them and everything was working like new , I haven't had any further problems since
Jul 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
I recently bought this turntable used. I am trying to connect it to a Sony receiver with a phono input, but no sound comes out when connected. Does this turntable require a pre-amp or something?
If the unspecified Sony has a "PHONO" input you should be good to go. What model?
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
http://shop.ebay.com/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 27, 2011 | Panasonic Technics SL-1210MK2 Turntable
HELLO,RECENTLY BOUGHT A ROTEL 1500 TURNTABLE BUT WHEN PLUGGED IN TO MY AMP I NEED TO TURN VOLUME TO FULL TO GET ANY SOUND.Only thing i can think of is that the wiring is fualty is it easy enough to rewire?...
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unidentified amp doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
Jul 14, 2011 | Audio Players & Recorders
How do I hook up a turntable to a Harmon Kardon AVR receiver? Can't find correct inputs. Thanks
A 'generic' turntable and a 'generic' HK AVR?
Or your TT may have i
Jun 16, 2011 | Harman Kardon AVR 65 Receiver
I have a T62 Stanton and I want to play it like a normal turntable. I conected it in the Behringer mixer using L/R cable. I cannot hear the bass sounds with my headphones. What is happening?
Is it connected to a "PHONO" input or something not labeled explicitly for PHONO?
"PHONO" is the only designated connection on an audio device that is literal and exclusive.Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some... http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Apr 17, 2011 | Stanton T62 Turntable
Turntable problems
buy a better record player
Sep 27, 2006 | Emerson NR303TT CD Shelf System
Hype HY-2004-BCT Briefcase USB Turntable/Vinyl Archiver with Built-in speakers - Rip Your Old Vinyl to MP3 Logo
43 people viewed this question
Top Hype Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hype Audio Player and Recorder Expert? Answer questions, earn points and help others
