Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Booster pump will not come on all the time
Checked booster pump and wiring and both are fine. Booster pump will move slightly from power board switch in Service Mode and sometimes come on. Motor shows power on terminals but motor won't work. Repeatily press button on power board to get motor to turn on. Sometimes turns itself off after a few minutes, sometimes stays on until button is pressed to turn off.
Jandy Aqualink RS8
  • 125 Answers
Link to the owners manual and trouble shooting guide
Posted on Mar 04, 2009
1987 nissan 300zx turbo 5 speed runs fine just doesnt have the power it used to
hard to diagnose whithout seen it, but; have you checked ignition timing.
cam shafts timing- looked at boost gage-if the boost indicator does not
move, check if the booster turbine are not jammed. Also would be good idea to check throttle position sensor output and catalitic converter for free flow.
Dec 03, 2012 | 1987 Nissan 300ZX
Wiring instructions to rewire Pentair universal booster pump from 240V(Factory wired) to 120V.
see side of motor for schematic for low voltage you have to move wires or change a switch
Jul 05, 2011 | Pentair 34 HP Pool Pressure Side Booster...
Brake booster appears not to be working properly. brakes work ok for 1 or 2 apps then pedal gets hard. cannot hear any vacume leaks. the car does have a vacume switch in the booster
the booster is the problem, or a hole or leak in vacuum line to booster check the check valve also ! from manifold. heres the symtoms of a bad brake booster. primary symtom is a hard pedal on application, to test booster. pump brakes several times with engine off. to deplete stored vacuum. turn on engine with pushing slightly on brake pedal. you should feel the pedal fade away abit and then become firm. but not hard. if you feel nothing at pedal when engine starts, brake booster is not working! check the vacuum lines first!!
Jun 11, 2011 | 1985 Pontiac 6000
My 2004 prius abs and brake light came on and the the brakes became very hard and constant beeeep noise, so i would shut the car off and pump the breaks and it would work fine so i decided to bleed the...
well, a hard firm pedal, usually indicates a bad brake booster or a vacuum leak to booster or the vacuum check valve, on booster. TO TEST BRAKE BOOSTER; pump brakes several times with engine off to deplete stored vacuum. turn on engine with pushing slightly on pedal. you should feel the pedal fade away a bit and then become firm, but not hard. if you feel nothing at the pedal when engine starts the booster is at fault. good-luck !!
Feb 03, 2011 | 2003 Toyota Prius
I have very little rear brakes on my 91 w350. the shoes are fine and so are the wheel cylinders. I have recently replaced the master cylinder and had the system power bled at a shop. Is it the...
I assume you bled the rest of the system. If so check your rear adjustment. Adjust the parking brake at the same time. If no fix, then open up your rear brakes and inspect the hardware, cylinder/caliper, and adjuster. Only after all that would I suspect the proportioning valve. Ways to test that vary vehicle to vehicle. Good luck!
Apr 20, 2010 | Dodge W250 Cars & Trucks
I have an Intermatic pool pump timer. The motor for the clock is running, but the on of switch will not trip. I made sure the stop/start pins are properly on. I did recently replace the switch below for...
If the motor doesnt have enough power to trip the switch you will have to replace it. The motor assembly is replacable without having to replace the whole box. I know you can get them at Lowes and Home Depot.
Sep 25, 2009 | Intermatic T104 24h 208-277v Mechanical...
Have hayward 2speed pump and cant get speeds to change ontime clo
If I am following your description correctly it sounds like the booster is tied to the wrong clock...You want the booster to run with the high speed which is 'the other' timer it sounds like.
Sep 11, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
My polaris PB4-60 booster pump does not turn over.
I was able to save a service call by doing the following in under 8 minutes:
1.Switch off electric to pump.
2. Turn off valve on supply side of pump so water does not flow during this procedure.
3. Turn offf filter.
4. Unbolt the six bolts (1/2" socket) on the front side of the pump.
5. Carefully separate the pump from the front panel which contained the six bolts.
6. Grasp with both hands the black round thin disk (impeller) which is part of the pump and turn it either clockwise or counter clockwise. It may be slightly difficult initially but once it it freed it will move easily.
7. Reassemble.
8. Open valve and turn on filter and the power to booster pump.
Any questions e-mail me at bbgreg@optonline.net good luck
May 16, 2009 | Polaris Pb4 - 60 Booster Pump
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
350 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
